Tach problems on 4th Gen (created post)
Old Aug 16, 2006 | 07:02 PM
miserov's Avatar
From: You can't spell 'Wisconsin is insanely boring" without "Wisconsin."
My tach randomly will start bouncing around, sometimes burying itself at 0, sometimes ~2,000 above what it should be, but a lot of just random bouncing. I have Vehicle Speed Sensor Malfunction trouble code (P0500), so I started with replacing the VSS. It made no difference.
My question is what should I try to tackle next? Is there another sensor or is it probably a cluster problem?
I have an A/T.
Old Aug 16, 2006 | 07:30 PM
Apparition's Avatar
Ichiban King
Originally Posted by miserov
Ah ****, sorry. I have an A/T.
TPS? well and if it does it just idleing, then perhaps IACV.
Old Aug 16, 2006 | 07:52 PM
miserov's Avatar
I guess I wasn't thinking through my original post too well. When I said it randomly jumps around, I meant that it does that while I am driving, but it has always gone back to normal operation by the time I stop, so I cannot say for sure if it is limited to non-idle periods.
As for the TPS, for brevities sake I'll just say that my mechanic recently reinstalled it and tested the voltages, so that's working fine.
Old Aug 16, 2006 | 07:54 PM
Apparition's Avatar
Ichiban King
well when I had my '95, when the fuel pump was going.. id be driving it and it would cut out and the rpms would jump around but I really doubt thats it..
Old Aug 16, 2006 | 08:04 PM
kil2board's Avatar
Stupid question but,is the car by any chance gearsearching at this time? because if it is, then you might have a selenoid problem with your tranny.
Old Aug 16, 2006 | 08:22 PM
miserov's Avatar
My car runs perfectly fine, just that the needle bouces around, so no.
Oh yeah, the cruise control will randomly stop working. Not sure if these two items are connected as there seems to be no correlation between when one stops working and the others functionality at that moment.
Old Aug 17, 2006 | 07:40 PM
miserov's Avatar
Does anyone have any ideas?
Lakersallday24
Nov 7, 2024 07:31 PM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
maximaham
Aug 7, 2015 01:11 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
