car will not start, not battery
Old Aug 17, 2006 | 04:13 PM
supazn
battery is 110% fine.
1st crank starts and dies after 3 seconds
2nd crank starts and dies after 1 second
all cranks after that, constant starter sound, engine wont fire up.
I'm thinking it is the fuel pump, any other suggestions?
99 max with 85k...
Old Aug 17, 2006 | 05:40 PM
Jwad00's Avatar
Sounds like a fuel delivery problem to me all right. Fuel pump is the first thing im thinkin. Then again it could be something simple as a fuel line clog or clogged fuel filter. Its rare but ive seen it happen. Most likely the pump though
Old Aug 17, 2006 | 05:48 PM
supazn
what is the culprit for a bad fuel pump, just time?
Old Aug 17, 2006 | 05:59 PM
96i30azn's Avatar
dunno, but look at the directions for a fuel pump change in the stickes. I would look at the fuse before changing the pump itself
Old Aug 17, 2006 | 06:23 PM
kcryan's Avatar
its fuel 90%, its getting spark cause it starts, its getting air, cause if it wasnt something would be seriously screwed up, so its likely fuel
Old Aug 17, 2006 | 07:05 PM
supazn
is there anyway to test a fuel pump?
Old Aug 17, 2006 | 10:29 PM
maxgtr2000's Avatar
KH3 by popular demand
Take the bottom hose off the fuel filter, crank, if fuel comes out it works, if it doesn't replace it. There should be pressure in the system when you remove the hose, if there isn't , that's another indicator, also double check your fuel pump fuse.
Old Aug 18, 2006 | 03:53 AM
njmaxseltd's Avatar
Check the ECU for any stored error codes before you start taking things apart.
Old Aug 18, 2006 | 06:39 AM
99grnmaxgxe's Avatar
I know exactly what is wrong: you need to go to the dealership and get your keys reprogrammed. While you crank, check if your security light is staying lit, if so I'm right.
Old Aug 18, 2006 | 07:02 AM
supazn
the security light IS staying lit but what could have thrown my keys out of whack? Would I need to bring both keys and car? If so, then I'd need to tow my car. Is there anyway to fix this myself?
Old Aug 18, 2006 | 07:21 AM
DcMaN's Avatar
i thought if the transponder is bad in the key it would just keep cranking and not start. Also clean your throttle body see if that helps.
Old Aug 18, 2006 | 07:38 AM
supazn
well, the starter is making noise just will not fire up, similiar to starting a car on an extremely cold morning, TB is fine, and fuel pump is fine as well.
Old Aug 18, 2006 | 08:44 AM
The dealership requires you to bring all keys and the actual car to them for the reprogramming, do this ASAP I had this happen to me 2 times, it's a PITA. That's a big reason as to why I sold my car.
Old Aug 18, 2006 | 09:24 AM
supazn
thanks man, I'm sure this is it.
Old Aug 18, 2006 | 09:28 AM
Me too. Oh BTW watch out they might tell you that your ECU is f*cked and charge you $1300 to fix it. Just tell them to reprogram your keys so you can drive it.
Old Aug 18, 2006 | 11:34 AM
supazn
does anyone know what throws the key program out of correct function so that this does not happen again?
Old Aug 18, 2006 | 02:59 PM
maxracer's Avatar
slowest 5-cylinder in the East
do you go through x-ray machines or other security devices at airports or military bases a lot? couple of my usb flash drives got fruxed by those.
Old Aug 19, 2006 | 07:29 AM
Yeah, any thing that has a strong magnetic field like when a cashier deactivates a theft device. Also never stick any other key except the factory one into the ignition. Should cost around $85 to get the keys reprogrammed. Something I also learned, be cool with the tow truck guy and he'll be cool with you. Both guys knocked off like 2 miles off my tow.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
