Now I am really frustrated...
It still leaks!
I noticed a small puddle of coolant leakage over the last few days. The puddle started with drips from the bottom of the A/C compressor. Just up to the right and above the alternator, I noticed what looked like the source. It looked like it was coming from the area near the water pump (the weep hole). I spent all night replacing the pump with a brand new pump, new seals (cardone from Kragen). The fit was exact, and when I took out the original Nissan pump, the seals did not look damaged...I figured it was good maintenance anyway, but now I have a fully functional water pump (stock) with two brand new seals (I bought an extra set just in case) and I still have a coolant leak.
Where else could it be coming from??? It's definitely originating on the passenger side, somewhere above the oil pan assembly...
I was able to get a picture of the potential leak location. Any ideas???
This is a wide shot to help you familiarize yourself with the location
This is the tight, up close shot of the leak.
Help is much appreciated. And forget comments about the rust, etc. I don't care how dirty my engine bay is.
Originally Posted by konak85
it could be the PAG oil lubricating the compressor. The oil kind of looks like anti-freeze but is thicker.
Originally Posted by cam_honestiam
It still leaks!
I recommend cleaning the area and check for anti freeze again? Now it's been a while but, is that under the valve cover next to the timing cover..
I finally just took it in because the "leak" developed into a pinhole fountain spraying directly into the alternator. Oops...
It was a gasket where the two metal pipes connect to the front of the engine, directly opposing the alternator. I had a feeling it was that gasket, but I thought it was another bolt somewhere else.
Anyway, the shop charged me $340 to fix it. The mechanic said there was too little clearance to remove one of the bolts, and he removed the alternator to get to it.
So if you have a leak, check for gasket leakage before assuming it is the water pump!
teejnut
03-10-2001 08:26 AM
