Tire Pressure!
Old Aug 17, 2006 | 08:43 PM
TunerMaxima3000's Avatar
Tire Pressure!
So this is the deal, stock SE spec calls for 32PSI in the front, and 29PSI in the rear, what about aftermarket tires? what are YOU running in your tires?
Old Aug 17, 2006 | 08:44 PM
Nissan 6's Avatar
35 all around in my falkens
Old Aug 18, 2006 | 03:58 AM
njmaxseltd's Avatar
32F & 28R for a nice smooth ride.
The car is front heavy, you should drop the rear pressure slightly to match the front tires footprint. Thats why the sticker indicates a lower rear tire pressure. Most FWD cars are set up that way.
Old Aug 18, 2006 | 04:25 AM
dgeesaman's Avatar
Maintenance Monster
Tire pressure is dictated by the car, not the tires. Unless you're using race tires, just keep with 32/29 or something similar.
Dave
Old Aug 18, 2006 | 05:52 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
i run what my tire says to run
Old Aug 18, 2006 | 07:23 AM
Timothios's Avatar
my tires say 50psi!
Old Aug 18, 2006 | 07:43 AM
95bluse's Avatar
A good thread (tread? )...I was wondering the same since I've switched to my 235/45/17 setup. Incidentally, my '95 SE says to run 33fr/32r for the OEM 215/60/15. I read that you "should" increase the psi by 1 psi for a corresponding step up in plus size. That means that I should increase mine by 2 psi to 35f/34r since i went from 215 to 235. This suggestion is mainly to protect your rims due to the smaller profile.
BTW I've never heard of 33 front & 29 rear, I thought all Maximas had single psi differential front to rear
Old Aug 18, 2006 | 07:51 AM
dgeesaman's Avatar
Maintenance Monster
Originally Posted by Timothios
my tires say 50psi!
No, they don't, they say "50psi maximum". You run them at the pressure appropriate for your car and driving conditions. IMHO, 35psi is about as high as anyone would want on the street, and 40-42psi if you're autocrossing.
Dave
Old Aug 18, 2006 | 10:35 AM
99se5speed's Avatar
SHIFT_up
This had nothing to do with Tire pressure, but i would recommend everyone getting Nitrogen in the tires instead of air. I just recently switched and it's WONDERFULL!!! (all the new auto makers are using it from the factory). I paid 26 bucks w/ lifetime refill. Just wanted to let you guys know.
Old Aug 18, 2006 | 11:34 AM
whitegold's Avatar
I dont get why nitrogen is that great? Am I missing something.
My tires are 31, 35, 30, and 34... I really need to invest in another air pump.
Old Aug 18, 2006 | 11:41 AM
95bluse's Avatar
Air is 78% nitrogen, I hate paying for air
Old Aug 18, 2006 | 12:44 PM
ThurzNite's Avatar
The costco guy said nitrogen's a bigger molecule, less likely to leak out. It's also lighter than "air".
I run mine 42/40 hot... which translates to about 32/32 cold.
Jae
Old Aug 18, 2006 | 01:12 PM
White Shadow's Avatar
Still chugging along...
Nitrogen is better becase it doesn't hold moisture and isn't as affected by temperature changes like regular air is. Grade "D" or "E" breating air like you will find in SCUBA or SCBA cylinders will work just as effecitively as nitrogen will due to its very minute traces of moisture. As to the question the OP asked, I don't know enough about that to have an informed opinion.
Old Aug 18, 2006 | 01:25 PM
99se5speed's Avatar
SHIFT_up
All i know is that when i put in pure Nitrogen, i recieved a better ride quality, the car felt more stable on the highway, and it reacts to bumps better and softer...
Old Aug 18, 2006 | 03:23 PM
Batxel's Avatar
blah
That's still a lot money for 20% more nitrogen. Do you really think its worth it or is it just your imagination coupled with finally getting correct air pressure in your tires?
Old Aug 18, 2006 | 03:41 PM
TurTLe*'s Avatar
i dont care about if its worth it to swtich what i care about is the price to top off nitrogen.
i run 36psi in minds as of yesterday.
Old Aug 18, 2006 | 04:06 PM
chillin014's Avatar
lets get this as a sticky so we can stop having threads and seeing how many idiots are running 50 psi in their tires because they read that on the sidewall.
32-35 is fine. end of thread.
Old Aug 18, 2006 | 11:47 PM
nguyen925's Avatar
i try to keep my tires at 35, but i think i have a leak in my tire wall somewhere.. .(front tires) i think i shall rotate them and see if the fronts just that much heavier. i dont think its supposed to be that way though.......whenever i check my pressure it always seems to look flat and never has 35 in it. it always drops to 31 or 32 and this is on just a couple of days driving. i hate used cars. NEW CARS FTW.
Old Aug 19, 2006 | 05:54 AM
chillin014's Avatar
Now there's a new concept. Tires leaking small ammounts of air??? Your car is trash go buy a new one.
I've seen it happen...cars considered salvage due to leaky tires
Old Aug 19, 2006 | 08:04 AM
cam_honestiam's Avatar
I run mine at 44 PSI cold. Three years like this, so far so good. No uneven tread, smooth ride...
Old Aug 19, 2006 | 09:05 AM
super6's Avatar
Dave
i beleive its a bit of both. oem tires on mine read 44 max psi, on new ones its 51. its better to go a bit higher than the recomended psi.
also, mine stock suggests 33 for F and R.
Old Aug 19, 2006 | 11:19 AM
Well I put 32 F and 30 R in mine and couldnt believe the difference, much smoother and handles much better. the tires were wearing oddly but they'd had about 40-50 psi in them before I got the car.
Old Aug 23, 2006 | 09:27 AM
veluvalisr's Avatar
Hi Guys,
Can you please tell me if "Douglas Performance GT-H" Tire is Good or Ok for my 95 Nissan Maxima Front wheels.
Thank you,
Ravi.
Old Aug 23, 2006 | 09:36 AM
scubasteve's Avatar
They suck. The ride VERY rough, handle and corner is killer sloppy, the grip is terrible in the summer and even worse in winter. The tread will be 1/2 gone after about 10,000 miles. Douglas tires are made by Kelly which is owned by goodyear.
Your better off with BFG's, i love mine
Old Aug 26, 2006 | 04:49 AM
dgeesaman's Avatar
Maintenance Monster
Higher max pressure requires a stronger tire. Just because a tire is OEM doesn't mean it's a performance tire, so you will frequently see different max pressures. I would also not be surprised if max pressure is related direclty to the speed rating of the tire, again something that will be different from OEM spec tires.
That's because you have a 2000. 4th gens weigh less and their pressures are reduced accordingly.
Dave
Old Aug 26, 2006 | 05:27 PM
Thorby's Avatar
I've heard less corrosion caused by H2O.
Regular compressed air from the gas pump is poisoned with moisture.
Old Aug 26, 2006 | 06:05 PM
njmaxseltd's Avatar
Thats because Nitrogen doesn't expand and contract as much when temperatures change. Your 32 PSI cold fill doesn't get much harder after the tire heats up. You might gain 2 PSI with Nitrogen, but with simple compressed air you'll gain as much as 8 - 10 PSI as the tire heats up.
Old Aug 26, 2006 | 06:42 PM
mszilves's Avatar
So then the consensus is you should go by the stock recommended pressure? Does anyone know then, if the profile/size of the tire makes a difference? Does that mean that if you go up to 225/40-18s, you should still go by the stock pressure, regardless of the maximum pressure of the tire?
Old Aug 27, 2006 | 03:24 AM
dgeesaman's Avatar
Maintenance Monster
While true, it's irrelevant when running alloy wheels.
If you don't have alloy wheels then it's safe to assume nitrogen holds no substantial benefits for you.
Old Aug 27, 2006 | 03:30 AM
dgeesaman's Avatar
Maintenance Monster
You will never find a consensus on this forum. You have to be careful whether to trust what you read, that's all I'll say.
However, there is consensus from experienced drivers and racers, and that is to use stock recommended pressures as a baseline and make tweaks from there. Tweaks such as:
- If the stock pressure is just one number for all tires, make the front a few psi higher than rear since an unloaded Maxima places more weight up front
- Add a few psi for slightly improved fuel economy on the highway, or when loading the car near its weight limit (like coming home from college )
Stock pressure. It may change some if you go with a drastically wider wheel, but unless you tubbed your maxima it would still be basically stock pressure.
Dave
Old Aug 27, 2006 | 12:30 PM
aih98max's Avatar
scoobystoned...
cough.....scubasteve....cough
Old Aug 27, 2006 | 08:16 PM
mszilves's Avatar
Dave
Thanks very much Dave, very informative and well put. Though I'm still relatively new, I've found that these forums have some great people, always willing to help, even for the smallest things.
Old Aug 28, 2006 | 05:33 AM
jjamzman's Avatar
I have played around a lot with the tire pressure and found these numbers to work well for both good handling and a reasonable ride.
H&R springs
KYB adjustables set at 1 front and back
Wheels- 17" American Racing Alloys
Tires - Michelin Pilots - 225-45 MH4
front - 30 psi
rear - 27 psi
Old Aug 28, 2006 | 06:14 AM
Bobo's Avatar
The recommended tire pressure for my 95SE if 33F, 32R.
For the last 18 months, I have increased the pressure to above that.
I am currently running Yokohama Avid H4S and the OEM 15" sawblades with tire pressure set at 36F, 35R. I let the tire pressure drop back down to say 34F and 33R and re-inflate, particularly if I am going to do any amount of highway driving.
I think over the long haul this will translate into somewhat better fuel economy and tire life, at the expense of a slightly firmer ride.
Old Aug 28, 2006 | 12:29 PM
95bluse's Avatar
H&R springs
front - 30 psi
rear - 27 psi
Those pressures seem a tad low since the OEM w/stock 15" sawblades are 33front/32rear (on my '95 SE anyway). Not very much lower, but I bet your car feels a little sluggish with a hit on fuel economy. I'm on eibach/illumina (setting 2 all around) & dropped back to 33fr/32r from 36/35. Big positive difference in ride, I'll monitor fuel economy.
Old Aug 28, 2006 | 12:32 PM
95bluse's Avatar
Good idea, I tried this, but on my 235/45/17's & lower suspension there is considerable difference in ride quality.
Old Aug 28, 2006 | 12:43 PM
jjamzman's Avatar
It might seem that way, but you have to remeber that these are also bigger tires. It doesn't take as much psi to support the same weight with a larger footprint. With these settings, the tires just barely have a perceptible flat spot on the bottom. I am getting 24mpg combined driving, so they are not dragging. The ride and feel are better and so is wet performance. With more air, it was easy to get the rears to brake loose in a hard stop. Not now. Everything seems better.
jjam
Old Aug 28, 2006 | 02:11 PM
dgeesaman's Avatar
Maintenance Monster
jjam
The point about traction is a good one. Going up in pressure always has a tradeoff, and it's not simply ride quality.
Dave
Old Aug 29, 2006 | 06:46 AM
95bluse's Avatar
jjam
Here's a thought.. a wider tire does not give you a "larger" footprint, it changes the shape of the contact patch. Typically, a high aspect ratio tire will have a long, narrow footprint, while a low aspect ratio will have a short, wide footprint. This is why wide tires tend to hydroplane more than a narrow tire & perform poorly in snow.
Old Aug 30, 2006 | 06:21 AM
jjamzman's Avatar
This is true to a certain extent that the aspect ratio of the tire affects the contact area shape. However, the 225-45's with the pressure adjusted to allow proper contact definitely have a bigger footprint than the 205-70's it arrived with. You would have to run the 205's very flat to match the same contact area. The performance would suck in that configuration. By the way, the Michelin Pilots are much better in the rain (less hydroplaning) than previous tires that I have run. They are also hands down the best performance tires that I have ever run in the snow.
jjam
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
