Gas Mileage Suffering
Old Aug 18, 2006 | 10:02 AM
Cosmo459sx's Avatar
My gas mileage is suffering and has been ever since I "modified" my catalytic converter. The Check engine light is always on and throwing downstream sensor codes. Everything else has been ruled out (new plugs, coils, pvc, air filter, IAC sensor cleaned, t/b cleaned, etc. I just didn't think the cat could have a negative effect on gas mileage since it is only the downstream sensor affected (which is not supposed to factor into the a/f or otherwise affect engine conditions). Is this not the case?? I'm considering throwing another stock cat back on, but figured someone could give me some real insight to my downstream sensor plight. Thanks in advance for any help.
Old Aug 18, 2006 | 10:18 AM
99se5speed's Avatar
SHIFT_up
I believe i have had a similar problem as you which was taken car of yesterday. I was getting a check engine for Bank 2 Sensor 2. The code was saying that there is high voltage going to the sensor. So i hooked up the consul (not the OBD-2) and monitered my real-time a/f ratios, and all the o2 sensors. That sensor was truly making mistakes and wasn't working properly. The graph was very unstable. I just replaced the o2, cleared the code and everything is good so far. But only 1 day has passed so i'm still skeptical. After I installed my y-pipe and cat i didn't reset the ecu for a reason, which was to wait and see if the car figures it all out on its own, which it did and threw the code. I was told to get an o2 simulator, but i haven't gotten around to that. So just check your real-time a/f ratio, and the o2's to see if it's really faulty. Hope this helps somewhat.
Old Aug 18, 2006 | 10:39 AM
Cosmo459sx's Avatar
where can i get one of those simulators please???
Old Aug 18, 2006 | 11:31 AM
whitegold's Avatar
o2simulator.com, or just google o2 simulators.
Old Aug 18, 2006 | 12:48 PM
Cosmo459sx's Avatar
thanks! much appreciated
Old Aug 18, 2006 | 12:49 PM
How did you modify your cat? and why did you?
Old Aug 18, 2006 | 01:26 PM
99se5speed's Avatar
SHIFT_up
He just changed his OEM to aftermarket, just as i have.
Old Aug 18, 2006 | 01:40 PM
happyricefob's Avatar
V^___^V
rear o2 sensor malfunctional
Old Aug 19, 2006 | 07:31 AM
99grnmaxgxe's Avatar
Funny thing is, rear O2 sensor should not effect gas mileage.
Old Aug 19, 2006 | 09:22 AM
sunten1
Could I buy one of these o2simulators instead of having my o2 sensor hang really low on my b-pipe
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
