Installing a VAFC II - Couple Questions
Old Aug 19, 2006 | 02:42 PM
MaximaEvolution's Avatar
I already have it mounted I just need to wire it. Now I know about the ground and power wires and connecting them at least 1cm apart. And that I need to tap in the Tach wire. Other than that, what wires need to be connected? I have a picture of a 97 ECU pinout, would it look the same for my 98?
Also, would it be easier to take out the ECU before wiring? What methods did you guys use?
Any help is appreciated thanks guys.
Old Aug 20, 2006 | 05:44 AM
buuump
10char
Old Aug 20, 2006 | 05:54 AM
sean05's Avatar
might get better result over in the all motor section..
Old Aug 25, 2006 | 06:26 PM
xHypex's Avatar
It's been a while since I installed (and later uninstalled) my SAFC II, but here are the diagrams I used.
Hope it helps
-hype
Old Aug 25, 2006 | 06:28 PM
xHypex's Avatar
Taking out the ECU isn't helpful because you need access to the harness itself. I had to remove a plastic cover on the top and carefully move wires around so I could count and tap into the wiring. I personally did not want to cut any ECU wires so I used taps; just make sure they are the right size and make a solid connection.
-hype
Old Aug 25, 2006 | 06:57 PM
MaximaSE96's Avatar
Maxima Owner
i used that diagram toooo...it helped a ton.....just disconnect the battery cables
but besides tach...u need to interupt the MAF wire......knock sensor....02 sensor....TPS sensor....pretty much that diagram Hypex posted....
Lakersallday24
Nov 7, 2024 07:31 PM
FlaMark
Jan 8, 2016 07:21 AM
t6378tp
Aug 24, 2015 07:03 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
