need 5 spd swap
Old Aug 23, 2006 | 05:22 AM
Yicco's Avatar
need 5 spd swap
hello 4th gen-ers. I myself am a third gen maxima owner, but a friend of mine in the CenTexNissan club has a 4th gen w/ auto tranny. his shifter control unit is gone bad, so instead of paying 800 for the unit, he just wants to swap to a manual. If anybody can offer some help, such as pictures, maybe even some advice on the hard parts of the swap (I've done it on my 3rd gen) that would be awesome, so I need:
manual tranny
shifter linkage
flywheel
clutch - if someone has a kit, I would gladly take it off your hands
tranny plate
manual tranny mounts
manual axles
clutch pedal assembly
brake pedal assembly (for manual car)
master cylinder, and lines of course
slave (if you don't include it w/ the tranny ur ghey)
and I think thats everything, probably the shift boot and cover for the interior. let me know as soon as possible. this car needs to get back on the road!! thanks
Z
Old Aug 23, 2006 | 05:58 AM
Zack342's Avatar
Check the link in my sig. i have the shift rods, clutchlines and shifter with hardware for sale.
Old Aug 23, 2006 | 06:06 AM
Yicco's Avatar
thank you, its a little out of the price range we are looking for. I appreciate the offer though.
Old Aug 23, 2006 | 06:39 AM
Zack342's Avatar
no porblem.
Old Aug 23, 2006 | 08:15 AM
WielkiWaac's Avatar
MaximaDriver
dont forget flywheel bolts. they longer
Old Aug 26, 2006 | 08:28 PM
Yicco's Avatar
once again, if you sell me the flywheel w/out bolts, I will consider you ghey!
Old Aug 26, 2006 | 09:50 PM
GoalieKeg's Avatar
Reuse the auto flywheel bolts...DO NOT use the longer manual flywheel bolts. Trust me.
Old Aug 27, 2006 | 12:18 PM
Yicco's Avatar
sure thing buddy, next I'll just throw the tranny in reverse going 90 down the highway.
Old Aug 27, 2006 | 04:05 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
wwwaaaaahahahahahahahah.......ill pay 100 bucks to see that.....
seriously i just did my 5spd swap
http://www.vqpower.com/v2/modules.ph...howpage&pid=30
go there and enjoy - remember to get a 5spd computer so you dont get a cel the auto will work im still using mine but that orange light will make you wanna kill yourself.
also if your using an aftermarket flywheel get the timing ring off a stock one youll need it.
Old Aug 27, 2006 | 04:30 PM
matts95max's Avatar
ok whoever says to use the auto flexplate bolts for the flywheel is dumb, they are about a 1/4 of an inch shorter..and you lose even more thread when us take into consideration little extra thickness of where the bolts go thru on the flywheel and that circle big washer thing..USE THE MANUAL ONES THAT ARE SUPPOSED TO BE USED THERE!!! learn from my mistake!
Old Aug 28, 2006 | 11:56 AM
GoalieKeg's Avatar
Ok, since you're so smart, tell me why you couldn't use the auto bolts. There's plenty of thread to grab onto when they're bolted to the crank.
The reason I say use the auto bolts is because during my 5spd swap, the manual bolts bottomed out in my vq30 crank, therefore completely stripping all of the crank threads when I tried to pull them back out. And when I did pull them out, guess what? about 1/4" of thread was stripped from the manual flywheel bolts. They weren't even all the way in once the manual bolt bottomed out either. The flywheel was clanking side to side. I blame it on the fact that somehow when the crank was made, Nissan didn't bore the holes deep enough. Or mabye with my particular model year, the crank holes aren't bored as deep...but according to nissan fast, there is only one crank made for the vq30, and vq30de-k. They're both the same.
I know what you're going to ask...did I use the spacer. Yes, in fact, I did use the spacer WITH the auto bolts. Next question you're going to ask is if I got the correct manual flywheel bolts. Yes, I confirmed that the bolts were the correct part number through nissan fast. They are about 1/4" longer than the auto ones.
Finally, you CAN use the auto bolts on the 5spd swap. Why in the world would you want to spend 40 bucks on 8 bolts that you don't need to use? I and many other orgers have used the auto bolts with no problem. Don't call me dumb when you don't even know what experience I've had with 5spd/motor swaps on the maxima.
Also, please explain to me your mistake. I'd like to know what happend when you installed the auto bolts, or if you even did for that matter. I'm guessing you didn't.
Old Aug 28, 2006 | 12:35 PM
i30ds's Avatar
Armed and Dangerous
Use the MANUAL bolts, period.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
