Attention To All 95 Owners...
Old Jun 25, 2001 | 09:18 AM
phatmax95's Avatar
how many miles do you have on your 95? i am lookin into getting a 95 so i was wondering after or around 100,000 miles, what all needs to be done, or watched out for.. any help would be greatly apprecited.. thanks ahead of time
Old Jun 25, 2001 | 09:27 AM
JeepRage's Avatar
154,000 miles... i am doing my front 02 sensors now. change tranny fluid, thats about it
Old Jun 25, 2001 | 11:24 AM
mzmtg's Avatar
Minister of Silly Walks
121,000 miles. I've only had to get the usual O2 and starter replaced.
Old Jun 25, 2001 | 12:27 PM
Sonic's Avatar
90,000 and all I have had to do is scheduled service items.
Old Jun 25, 2001 | 01:30 PM
tiedyemaxima
135,000 when i bought it all i have had to do is replace the starter. and i have had a check engin light on so i am guessing from what the other guys wrote mine might be the o2 sensor.
Old Jun 25, 2001 | 02:06 PM
1Phat Max's Avatar
just hit 50k yes'day and had to change my starter...looks like starter and o2 sensors are two major defects in 95 max's...
Mishmosh's Avatar
67,000 miles. one o2 sensor died under warrantee. Regular maintenance and upgrades. Was hard to crank in winter--suspected spark plugs since it was fine previous winter and I had just put in Bosch plugs in the fall. Now its warm and I went with NGK--car starts fine but hopefully not a new starter next winter. Absolutely love my car more than ever now...
Old Jun 25, 2001 | 02:07 PM
95GreenGLE's Avatar
95,000 miles, change tranny fluid, usual o2 problems, i think starter might be going. not bad for 21,000 miles in 10 months (i drive too much)
-Barto
Old Jun 25, 2001 | 04:27 PM
Micah95GLE's Avatar
111,000 miles. Replaced O2 sensors at 57K, starter at 80K, and oil sending unit a few months ago. No problems other than that.
Old Jun 25, 2001 | 04:39 PM
maximomo's Avatar
122,000 miles
Up till now this car has been great. 29MPG hwy with an AT!
I'm about to replace all 3 O2 sensors and the knock sensor.
I hear this is pretty common. Otherwise, great car.
Old Jun 25, 2001 | 07:29 PM
hockeyghst's Avatar
Re: 122,000 miles
Only 49,000 miles on my 95 max......it was a garage kept car before i owned it......evrything is working fine right now...
Old Jun 25, 2001 | 07:33 PM
Whitemax's Avatar
Disco Biscuit
121,000 miles, had to replace the AC compressor. No probs with starter or O2 sensor (yet)
Old Jun 25, 2001 | 08:43 PM
plrod Black 95 SE's Avatar
I'm just under 62K; only things that've gone bad are the starter around 35K and the windshield washer pump around 20K; both were warranty items when they went bad. Oh, I also have very squeeky rear door hinges which I think there was also a TSB on but my dealer f'd up the order and I forgot to follow up so I just live with it.
Old Jun 25, 2001 | 09:25 PM
emax02's Avatar
My 95 Maxima has 96K miles and I have replaced my Clutch, E-Brake Line and 2 O2 sensors. Other then that the car runs great!
Old Jun 25, 2001 | 09:47 PM
piopremier's Avatar
49,000 and counting. only thing ive had to replace is the starter
Old Jun 25, 2001 | 11:00 PM
guido_sst's Avatar
I've got just a touch over 70,000 miles. One O2 sensor and one revolution sensor replaced under warranty, nothing but regular maintenance since.
Old Jun 25, 2001 | 11:02 PM
mtl95se's Avatar
I have 159k kilometers, about 100k miles....I've had no problems just scheduled maintenance, and my car is driven in harsh winter 4-5 months a year...
Old Jun 26, 2001 | 06:35 AM
fivelitrekiller's Avatar
I have a whopping 153,000 miles on my beast...or 245,000k. She's running just as strong as the day I bought her. The only things I've done that were necessary were an alternator rebuild, tranny rebuild(yeah, like that's a shocker!) and an O2 sensor...that's aboot it!
good luck, you shouldn't be disappointed in a high mileage 95, if it's been looked after properly.
G
Old Jun 26, 2001 | 09:50 PM
GarthG's Avatar
Mine has almost 110K. . . Only thing that had to be replaced was the starter and the A/C compressor (Under warrenty at about 60K). Clutch has also gone out twice, but the second time was due to a crappy install the first time which caused it to fail within a year. Other than that, just normal stuff. . . Brakes, Struts, Battery. . . Nothing to expensive.
Old Jun 27, 2001 | 12:12 AM
buss95max's Avatar
131k
Old Jun 27, 2001 | 02:58 AM
gibsot's Avatar
2130,00
Starter 150k
water pump 204k
don't take to Firestone
put a new engine in at 206k
Firestone took timing cover off to replace waterpump and could not stop it from leaking oil after the repair.
Old Jun 27, 2001 | 07:11 PM
MAXINXS's Avatar
My 95 has 143,000 miles on it. Runs just as good as it did when I got it at 103,000. You gotta love the quality of our engines! I have replaced the transmission, starter, and two clutches. I'm about to change the clutch again and put in an ACT one.
Maxima_Joe
Nov 25, 2015 08:19 AM
schmellyfart
Sep 25, 2015 04:47 PM
umnitza
Sep 1, 2015 01:03 PM
MaxiMike
Aug 29, 2015 01:13 PM
mel
Apr 1, 2001 02:11 PM
