de-k swap Questions
Old Aug 27, 2006 | 09:32 PM
95turbo gxe's Avatar
de-k swap Questions
OK I searched but alot of it was old info.
Ok i got my dek engine and im wondering a few things.
1st can i just cap the egr off and not use it. And if I do how will it run?
Ok the injectors plugs are no big deal to splice them.
OK Can I use a 95 y pipe with this engine?
I have a neo to controll the vi what rpm should I set it to to work the best.
And finally what eles do i have to do to make this swap work
Old Aug 27, 2006 | 10:34 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You can use your 95 ypipe as long as you swap over your front exhaust manifold from your 95 engine.
matty's Avatar
I totally took the EGR off the car, welded the hole in my new headers, capped the vacuum lines running to the EGR, and capped the intake plenum. Havent really drivin the car yet so I dont have any feedback
Not a big deal. I know guys that did it. I used 4th gen injectors, 4th gen lower manifold.
Yes
4800-5100 I think is best depending on what other mods you have
What eles do i have to do to make this swap work
Thats kind of an open ended question. Depending on what kinda mods you wanna do as your adding the motor in. Some things are easier while the motor is out. For instance the steering rack, or the alternator. I did both and alot more when I did mine. For a direct swap, you dont need much.
Old Aug 28, 2006 | 08:05 AM
So the tps sensor will go the dek throttle body and plug up?and what is a coolant log?
Ok I see what you mean about relocating the iacv as it does not have a place to mount iirc.
And where can i get the fuel rail fitting to do away with the damper? and If im using a after market fuel pressure reglator wouldnt it be agood idea or easyer just to do away with the stock regulator as well?
Old Aug 28, 2006 | 10:47 AM
Yeah Thanks I see now i just went and look at my dek motor today and it has the egr all ready cap at the manifold and at the intake manifold. I seen on my engine the vi has two plugs on it and the other engine I seen only had one whats the differance in the two vi's. Right at the vias two connectors under the vacum ports.
Old Aug 28, 2006 | 10:53 AM
gtr_rider's Avatar
192.168.1.1
You may have gotten a Cali-spec motor, so i would check if you have butterfly flaps in your lower plenum as those need to be removed. the passenger side connector is the VIAS switch.
Old Aug 28, 2006 | 11:40 AM
AHow can i tell the diffrance in the motors by looking at them? Is their anything i can look at to tell?
Old Aug 28, 2006 | 12:11 PM
i30dvr's Avatar
well a cali-spec motor will have 4 o2 sensors on the front of it
Old Aug 28, 2006 | 01:30 PM
well I had nissan to look up the vin of the car that the motor came out of. they say that its a fed motor. it came out of a 01 I30. But it has the swirl valves. It has no egr it is capped off already
Here is one of the pics this is down on the timming chain side on the lower intake.
Here are some more pics Also the pic of the sensor on the back of the motor circled in the 2nd pic what is it and what does it do?
Old Aug 28, 2006 | 02:27 PM
new pics bump in last post
Old Aug 28, 2006 | 06:31 PM
d00df00d's Avatar
Old enuf to pick his own gears
R.E. the 3 pics above:
1. That is the canister that actuates the swirl valves. If you don't give it vacuum, they will stay open.
2. The electrical plug on the left is to control the variable intake. The one on the right is for the swirl valves.
3. That looks like the EGRC solenoid... Not sure though.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Johnny9595
Sep 3, 2015 05:18 AM
