electrical help! 98 i30
hey guys last night i noticed that my pass. rear brake light was not working so i went to a super market and got some cheapy taillight bulbs and replaced it...seemed like it worked fine at the time but the next morning i noticed that when the headlights are not on when i apply the brake my front signal lights turn on and turn off once i let go of the brake pedal, i also noticed that the digital clock and guage cluster does the same...after a few min of driving it stopped but them i noticed that now my signal lights and rear parking lights are not working so i check the taillight fuse and its broken so i change the fuse and now the parking lights work but when i apply the brake the signal, digital clock and gauge cluster turn on and off and again after a few min of driving the fuse blows again....where do i start? anyone have any simalar experiences????
thanks
Greg
thanks
Greg
Have you made any electrical changes since the last time everything was for sure known to be working properly? Have you installed a new head unit, alarm, foglights...anything? If so, go back and verify all your connections are correct. I know that when I replaced the factory radio in my girlfriend's 3rd gen a couple years ago, there was an "illumination" wire on the new deck and an "illumination" wire in the factory radio wiring in the dash, so I thought it made sense to connect them. After doing that, I got all kinds weird crap happening. It was blowing fuses every time I touched the brake pedal, instrument lighting going out, etc. Disconnected that wire and then everything worked properly again. Hope that helps.
no i havent added anything to the car but these weired things started to happen after i replaced the brake light bulb with the cheap super market ones so i im going to take it off and see maybe the wattage is too high? or maybe a wire grounding out???
thanks for the help
thanks for the help
Is the bulb, sometimes the contacts for high/low meaning parking light and stop arc. What will happend is that when you press the brake with the lights off they will turn on. I had that issue before with cheap bulbs.
ok heres the update:
it was the bulb that i used for the brake light i didnt notice that the bulb i bought from the super market was a single filament (105) when the stock bulb should be a dual filament (3496) so its all fixed!
thanks for the help!
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
