ECU codes 33, 34, 53, 77 HELP!
Old Jun 25, 2001 | 04:34 PM
maximomo's Avatar
95 Max - Error codes 33, 34, 53, 77 together Need HELP!
Originally I was getting intermittent O2 codes that would go away when I cleaned each respective connector under the hood and reset the ECU. Now, no matter what I do I still get all 3 O2 sensors failed and the knock sensor. I read somewhere there is a harness problem with a TSB from nissan that deals with this issue. I can't find it or any details now. Does anyone have experience with this?
If it's wiring I'd like to know before I replace $350 worth of parts that I may not need.
Paul
Old Jun 25, 2001 | 06:51 PM
gtr_rider's Avatar
192.168.1.1
Re: 95 Max - Error codes 33, 34, 53, 77 together Need HELP!
They're read like this, 0303 - Front Left Heated O2 sensor
0304 - Knock Sensor
0503 - Front Right Heated O2 sensor
and last but not least 0707 - Rear Heated O2 sensor
sounds like your car needs a whole lotta sensors to me.
Old Jun 25, 2001 | 09:39 PM
emax02's Avatar
I think theres a o2 sensor fuse, this may be your problem. Check the fuse and if it is fulty replace it and your problem will be gone, if not then I have no clue.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
