Cleaning Ur Engine
Old Sep 3, 2006 | 09:17 PM
airness_81's Avatar
Cleaning Ur Engine
Do you think its a good idea to spray a engine decreasser to your whole engine if you want to remove every oil in your engine?When i read the direction it say that u need to cover ur coil and filter but theres no way to cover each coil of my car.Any idea wat is the best thing to removed the oil in ur engine?
Old Sep 3, 2006 | 09:19 PM
Nissan 6's Avatar
If you want to remove your oil loosen up the drain plug.
Fang_DH's Avatar
I'm about to use Black Magic's Engine Shine. Just make sure not to get any in your air intake or or your alternator, and if it has you rinse it off use low water flow and cover and exposed electrical connections.
Old Sep 3, 2006 | 09:24 PM
Fr33way™'s Avatar
Wild for Width
Your typing is near flawless.
Old Sep 3, 2006 | 09:27 PM
96blkonblkse's Avatar
you should be fine, just cover up your altenator make sure you dont directly spray into that or right into the intake. Also make sure the car is NOT running while you do this. Simple green and a good brush works really good too.
Spak97max's Avatar
i use black magic it works pretty good just get a "toothbrush" or somthing like it to scrub all the hard spots =)
Old Sep 3, 2006 | 09:33 PM
drudoggab's Avatar
i agree, but if you want to get oil OFF of the engine, then you have to use a degreaser, not sure what a decreasser is there are no creases in my engine.
but in all seriousness, i usually take a plastic bag to one of those coin-op car washes, cover my intake, spray the engine cleaner, let it sit for a few, and then rinse.
don't shoot straight at the alternator and the coilpacks and they will be fine. worst i have ever had was a hard start afterwards, and that was only once on my jeep, i've done it dozens of times. works great for me.
Old Sep 3, 2006 | 09:35 PM
llama's Avatar
You're online attitude IS flawless, if you are an E thug.
Old Sep 3, 2006 | 09:37 PM
yeah you should be fine, i do it all the time at work, and basically the only thign ill cover up is the altenator if its eassily sprayable or the distributor if the car has one. I use a pressure washer at work and some degreaser type stuff, if you get the degreaser stuff on the plastic you should use something to put on the plastic afterwards like a plastic/rubber protectant
Old Sep 3, 2006 | 10:45 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
Uhhhooo I guess I might regret this a little later...
Old Sep 4, 2006 | 10:10 AM
Blackwind's Avatar
i have never coverd the alt. when i washed my engine.
Old Sep 4, 2006 | 10:49 AM
slicey's Avatar
yeah, me niether, plus i have drenched the interior of that thing w/ foaming engine bright then generous amounts of agua.
two other areas to avoid: if using pressure washer, don't aim sprayer at firewall and no degreasers on strut tower. there's a pricey plastic bearing near top that could lose its lubricant.
Old Sep 4, 2006 | 10:52 AM
slicey's Avatar
a little gojo w/ pumice and the right brush for the application works well for any bulit-up grimy areas on bottom of engine.
Old Sep 4, 2006 | 11:13 AM
Apparition's Avatar
Ichiban King
yeah dude gojo will take tree sap off your car lmao and you wouldnt think the stuff could do anything.. I used to use it on the engine but now that thing is so clean i just rinse it every once in a while and thats it.
Old Sep 4, 2006 | 11:14 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Should it not be:
You're online attitude is flawless, IF you are an E thug.
...still uncertain as to how a correlation may be drawn between the two.
Old Sep 4, 2006 | 12:18 PM
Apparition's Avatar
Ichiban King
Originally Posted by Metal Maxima
Should it not be:
perhaps e-thugs have flawless attitudes, ipso facto, you have to have a flawless attitude to be an e-thug.. in ethics we'd say this conclusion doesn't justify the ends (only in many more in depth words).
Old Sep 4, 2006 | 01:37 PM
Even with all of this taken into account an attitude is purley subjective (i.e. arrogance v. confidence) ergo cannot be deemed 'flawless'.
Old Sep 4, 2006 | 01:56 PM
AxisKill's Avatar
if you're going to degrease your engine i'd reccomend covering all wiring and harnesses with aluminum foil. Then spray carefully on trouble spots, let it sit for a bit (to eat away) and then put on a glove (if you want) or just grab a paper towel and rub away at dirty spots. Then get a high pressure hose and spray everything down (even though all your electricals are covered try not to get too much on there) then take out a paper towel and dry everything off... let it sit for a while so everything dries on its own, and then cross your fingers, start your car and hope you didn't fry anything
kil2board's Avatar
this is true with the sturt tower. however the plastic bearing is not TOO pricey, (5 bucks), its the labor that really screws yea.
Old Sep 4, 2006 | 03:27 PM
Blackwind's Avatar
You do not have to cover anything when you wash your engine, i will send you pics of my engine bay and i degrease EVERYTHING!!
Old Sep 4, 2006 | 06:25 PM
AxisKill's Avatar
Degreasing isn't the problem.. its when you wash it down with a hose.. water + electrical =
Old Sep 4, 2006 | 06:31 PM
lilaclucymaxima's Avatar
Team Ramrod
Ridiculous... check the detailing section.
Old Sep 4, 2006 | 07:23 PM
Apparition's Avatar
Ichiban King
agreed I was getting at the flaw in the theory itself..
Old Sep 4, 2006 | 09:23 PM
slicey's Avatar
great price! got my quote from pinnacle nissan @ $ 25. for ea. or the pair..........memory fading fast.
Old Sep 4, 2006 | 09:39 PM
slicey's Avatar
about drenching the electrical harness during rinse-ever take a close look at some of the harness plugs? they have pretty good rubber(or something) seals for keeping water out. like on the coil and injector connections.
however, you know about the dielectric grease one should apply to the plugs and their boots? a few times now, i've used an electrical contact cleaner on major harness plugs under the hood, then applied the aforementioned grease to each as a water repellent and lubricant.
just something to think about if one is so worried over short circuits occurring.
derekinthez
Nov 13, 2022 04:00 PM
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
