Problem with automatic shifter and start.
Old Sep 5, 2006 | 10:04 PM
NyCzBuBBa's Avatar
Ok I'm having a huge problem getting the shifter out of park. I have to jiggle it around before the button can be pushed and then I can put it into drive. Then after I put it into park again I can take it out easily but if the car sits in park for more than 5 min it will get stuck again. It's like when you don't hit the brake and your pushing the button I pump the brake but it doesnt work. Ok now I have this other dilemma with the start sometimes. I'll turn the key and get nothing not even a click. Then I put it into neutral and it starts sometimes. Sometimes it just turns too. Anyone know if that is the shifter or the key ignition. So my question is should I change the whole shifter? Is it easy to remove and replace? What to do? need help!
Old Sep 5, 2006 | 10:34 PM
96sleepergle's Avatar
sounds like prnd21 switch is the problem its located on the driver side on the transmission its a cable with little boot onit check the connection my brother girl friend i 30 had the same problem
Old Sep 6, 2006 | 02:20 AM
NyCzBuBBa's Avatar
underneath the car? Or inside the car? Also what is this to fix the starting problem or the button problem?
Old Sep 7, 2006 | 10:56 AM
NyCzBuBBa's Avatar
bump...........
Old Sep 7, 2006 | 11:25 AM
Chickan's Avatar
both are the same problem. There is a clutch interupt switch that keeps you from starting your car unless it is in Park/Neutral. It might be the actual switch on the gear selector. My gf's 94 Sentra has the same problem, but her switch was actually in good shape. I think her problem is the actual inhibitor itself, that is attached directly to the transmission and is a ~$80 part.
Old Sep 7, 2006 | 08:24 PM
matrix11229's Avatar
I have the same problem with the shifter button. It gets stuck once every few weeks. If it gets stuck I push the car forward a little bit and it solves the problem for 2-3 weeks.
Mar 12, 2020 12:06 AM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
ef9
Sep 10, 2015 10:35 PM
