Cleaning Battery Corrosion
Hey guys my aunt's battery is corroding pretty bad and the mechanic says that it needs servicing. Instead of paying $20 I rather do it for her. The thing is, I don't know how
. Can anyone tell me how? And is there some sort of red grease to put around the terminals to prevent further corrosion? Thanks.
D/C the battery (duh) get some baking soda and water, mix it up and clean battery terminals with a wire brush. You can also do this to the connector parts of the battery cable. To prevent further corrosion there is some steel wool kind of rings that you can put around your batery terminals, goto autozone or some store, they will know what your talking about.
At almost any automive store they should sell battery post cleaners. It is a cylinder that fits over the post with a wire brush inside and the cap comes off and there is a wire brush for the connectors. Also get the felt like rings for the battery posts.
Buy a dedicated batter corrosion cleaner. Stuff is cheap, spray on, and has a corrosion inhibitor. Use a battery terminal brush too. I've done this many times on diesel truck batteries (4 - 6 large batteries per vehicle) and have never had problems with corrosion coming back.
is anyone elses positive battery cable like re-clamped 80 times and looks like complete sh*t? i dont know how to replace that cable but it looks absolutely terrible like its been cut and reclamped over and over.
Just run your own ground wires, I'm about to do this myself. You can use 10 gauge but i'm not playing games so i'll be doing the 0/1 AWG. I'm just having trouble finding the right copper connectors for the cable, if someone might know where i can buy such big connectors...
Wheel cleaner eats that stuff up too. Spray some on the battery terminals next time you wash your car then hose it off. Grease up the terminals to keep them clean. WD-40 works great at preventing corrosion.
those of you using coke? didnt anyone see myth busters, your myth is busted! besides liquid can cause corrosion, i seen many electronics with spilled coke, and it aint pritty.
anyways, thanks for the tips on bakeing soda and water, i heard this in the haynes manual.
I agree with all of the above. Bi Carb soda, or soda ash and warm water works best it just dissolves off. Then spray your terminals with CRC, WD40, Inox or lanotec, or even fish oil, you can even use plain ordinary grease.
