How The F**K DO I Change My Rear BumPer?!?!?
Old Sep 9, 2006 | 01:48 AM
The Russian's Avatar
so my bumper now is all ****ed up so i got a new one, and its already painted and all, i just need to put it on, how hte hell do i do that? i dont want to mess somthing up =/ HELP ORGERS!!!
Old Sep 9, 2006 | 03:03 AM
PARALLEX's Avatar
i take it u havent looked in a haynes repair manual yet huh??? check under body section it has step by step instructions...
Old Sep 9, 2006 | 04:23 AM
njmaxseltd's Avatar
Take out a few clips and screws from the bottom. I think there are a few that go across the rear and one or two right in back of the rear wheel.
Then fron inside the trunk you need to remove a few bolts holding the cover to the chassis. There are 2 in the lower corners inside the trunk. Pull the trunk lining out to get down into the corners. One bolt sits forward and one sits right in the corner. All are 10mm. Should take you no more then 15 - 20 min. to get the cover off. Look at the new part you have to see where most of the bolt/screw/clip locations are, then find them on your car.
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
steven4838
Aug 26, 2015 11:04 AM
laflyer23
Aug 22, 2015 10:04 PM
maxipower
Aug 21, 2015 11:10 AM
