Wheel Spacers...
Old Sep 9, 2006 | 05:28 AM
ThisMaxIsTight's Avatar
Wheel Spacers...
ok guys well I got some 15MM H&R spacers for the rear... I dont know what he was thinking but a veteran mechanic had informed me that 16mm was close to an inch...for some odd reason I didnt give it too much thought ...also reading peoples posts about wheels spacers and what seems pretty common is about 15mm and 20mm... so I just went ahead and bought some 15mm's .... I have a 42mm offset rim .... so with the spacer ill have a 27 offset in the back.... the 15mm's arent nearly as thick as I thought theyd be and looking at the rims on my car it just doesnt look like it would push it out that much.... IS THIS AN OPTICAL ILLUSION?... I dont know If i need to go wider or not... I just want the rim to sit close to flush on the rear .. what are peoples offsets ??
Old Sep 9, 2006 | 07:34 AM
lookin for some answers please
Old Sep 9, 2006 | 08:05 AM
Mxrider52's Avatar
I support for what?
35mm offset for me and they sit pretty much flush. 27mm offset will be sticking out of the fender.
Old Sep 9, 2006 | 08:10 AM
Black Maxima
Look in my signature. I believe my wheels are a 40mm offset.
Old Sep 9, 2006 | 09:04 AM
cefiro8701's Avatar
k...
im gonna tell u right now...stay away from these da.m.n spacers!
if one breaks cause of a pothole ur gonna get screwed...also many tire places are refusing to work on cars with spacers installed...
Old Sep 9, 2006 | 09:19 AM
1FSTMAX's Avatar
Originally Posted by cefiro8701
k...
dude using spacer without extended wheel studs is an accident waiting to happen... i used some 5mm spacer on my 97 and i made sure i used longer wheel studs, i dont care what anyone says about using stock studs.
Old Sep 9, 2006 | 09:29 AM
MaximaSE96's Avatar
Maxima Owner
i have 20mm specers milled down to 16.5mm with longer studs and have no problems...whell offset is +43mm
Old Sep 9, 2006 | 09:53 AM
cefiro8701's Avatar
any aftermarket spacer is an accident waiting to happen...
Old Sep 9, 2006 | 10:34 AM
1FSTMAX's Avatar
i bent one of my 18" wheels on a huge pot hole, i have extended wheel studs and nothing broke, or came apart. so you're statement is false.
Old Sep 9, 2006 | 09:16 PM
bump for some good info .... spacers are completely safe with longer studs and as long as its a quality brand .... H&R=tried, tested, and true
Old Sep 10, 2006 | 04:25 AM
njmaxseltd's Avatar
24.5mm = 1 inch.
Old Sep 10, 2006 | 04:43 AM
cefiro8701's Avatar
put it this way...let's say you have ur car is in the working bay in a shop that i work at...
as soon as they spot a spacer- they're gonna drop the project right away. Basically they dont wanna have to tell you that they told you so.
That's cool that you run ur car on spacers and ****...but is the added risk worth the "flush" look?
Old Sep 10, 2006 | 11:41 AM
MorpheusZero's Avatar
Originally Posted by njmaxseltd
24.5mm = 1 inch.
Um.. 25.4 actually. But yeah.
Old Sep 10, 2006 | 02:28 PM
MaximaSE96's Avatar
Maxima Owner
spacers are perfectly safe....shops are retarded and the mechanics u work with are too if they say that....i hive hit many pot holes bumps TRACK DAYS never had an issue......in my cause its out of necessity to clear some massive brakes....
Old Sep 10, 2006 | 10:22 PM
cefiro8701's Avatar
i wouldnt go so far as to say that someone's retarded...personally i wouldnt want the liability of a customer's wheels falling off.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
