need help replacing axles
Old Sep 10, 2006 | 09:15 PM
thumper10s's Avatar
got a 97 max gle that i am replacing the axles on, i got them disconnected at the wheel you could say, but where or how do they disconnect from the tranny
thanks
Old Sep 11, 2006 | 04:27 AM
njmaxseltd's Avatar
Just pull them out. The drivers side will pop out easily, the passenger side will be a PITA to seperate at the carrier bearing. Three bolts hold the passenger side axle to the carrier bearing. Then pry and pull really hard. If it doesn't seperate, take the whole assembly out and try seperating it once it's out of the car.
Old Sep 11, 2006 | 10:13 AM
thumper10s's Avatar
does it separate betwenn the two plates or on the out side, where do i pry
Old Sep 11, 2006 | 10:46 AM
MireLanski's Avatar
Do you have a prybar? You want to pry where the axle slides into the tranny housing. Don't kill yourself. If it doesn't come with moderate force try the passenger side.
Although everyone says the driver's side is cake it was not for me. My passenger side slide out with virutally no pulling force. Then I had to use a punch tool and mallet to knock out the driver side.
Old Sep 11, 2006 | 11:30 AM
thumper10s's Avatar
drivers side pulled right out, i cant get the passenger side though, and yeah i got a few prybars
Old Sep 11, 2006 | 01:36 PM
thumper10s's Avatar
yea screw the prybar, i grabbed the air hammer, out in a jiffy
Old Sep 13, 2006 | 08:25 AM
f550maranello2's Avatar
get some pb-blaster or wd-40 and soak teh bracket... its rusted to s.hit by now...
Old Sep 13, 2006 | 11:45 AM
thumper10s's Avatar
yea it was rusted, but the air hammer got it apart
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
