90K question
Old Sep 12, 2006 | 10:52 PM
ComradeJew's Avatar
90K question
Hi all,
My car is at 82K right now - 90K would be up in about 6 months or so.
What parts / brands should I order for the service, and what should I do?
Obviously - plugs, coils, air filter, fuel filter, water pump... but what else?
edit: on a side note - how hard is it to buy and wire up OEM fog lights?
Old Sep 13, 2006 | 05:44 AM
maxima1380's Avatar
NGK plugs, K&N filter or intake, water pump not needed, OEM belts, and radiator hoses.
Old Sep 13, 2006 | 06:11 AM
ComradeJew's Avatar
Whats the water pump replacement interval?
What about fuel filter?
Old Sep 13, 2006 | 06:17 AM
dmBK's Avatar
How 'bout them cliffs?
get everything OEM. www.courtesyparts.com cant go wrong.
Old Sep 13, 2006 | 09:05 AM
99grnmaxgxe's Avatar
Make sure you check all the fluids also.
Old Sep 13, 2006 | 09:23 AM
Bobo's Avatar
What you need to do at 90K is a function of what you did at 60K and beyond.
If you replaced the plugs at 60K with OEM platinum plugs you are still good to go. If the plugs were replaced with coppers, you may need to replace them.
If you have already replaced belts, you are still good to go. If no hoses have been replaced you might want to consider replacing them.
I suspect you should replace the fuel filter. It should be done every 30K. Replace the PCV valve if it hasn't already been replaced. If it has been replaced you are good to go.
Replace the air filter if necessary.
When was the last time the brakes were bled?
Was the radiator coolant and transmission fluid replaced at 60K? If so, it should be replaced again.
Has the power steering fluid ever been replaced? If not, replace it.
You might want to clean the throttle body and idle air control valve.
If the coils are working fine, leave them alone.
02 sensors and knock sensors should be replaced on an as needed basis. If it ain't broke, don't fix it!
Old Sep 13, 2006 | 10:34 AM
ComradeJew's Avatar
Well I JUST got the car so I have to go through maintenance records again to see what was actually done.
IIRC, the guy did change fluids, but only radiator fluid. I am gonna flush it anyway.
I think I might as well give it an all around tune up just to be on the safe side; gonna get valves adjusted as well.
I'll get new power steering fluid and i am having new brake pads coming in.
Old Sep 13, 2006 | 11:01 AM
dmBK's Avatar
adjust the valves? no need for that.
Old Sep 13, 2006 | 11:13 AM
Nissan 6's Avatar
If you change the fuel filter, get the 300zx one. It lasts twice as long as the maxima one so you dont have to change it out as often.
Old Sep 13, 2006 | 11:30 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by ComradeJew's Sig
Sigs are for loosers
Might want to check the spelling for some loose ends....
Old Sep 13, 2006 | 01:03 PM
ComradeJew's Avatar
I did it for a reason
Old Sep 13, 2006 | 01:56 PM
NmexMAX's Avatar
dot dot dot ...
I know, but the irony is thick And 93% of the people on here spell it that way and think it's ok...
Old Sep 13, 2006 | 05:44 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
that's some good advice ... i'm gonna follow this as well
thanx
Old Sep 27, 2006 | 04:34 PM
dmw1eva1's Avatar
Signal Light
I have a 98 Maxima and about 1 month ago whenever I hit the signal light (right or left) the light blinks but also makes some type of "pinging" sound in addition to the normal "clicking" sound you hear. Any ideas what this is and how I can fix it?
Old Sep 27, 2006 | 05:46 PM
kcryan's Avatar
Bobo got it
Old Sep 27, 2006 | 06:09 PM
sky jumper
i would add:
- brake fluid should be completely flushed (not just bled) every 3 years.
- do not mix coolant types. when in doubt, do a complete flush and replace with any of the Japanese OEM coolants or Zerex G05.
- flush the trany fluid (not just drain/fill). go to the fluids forum for DIY instructions.
forget the water pump and valve adjustment. not needed at 90k.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
