View Poll Results: Which Tranny fluid should I get on my 5spd mAx SE?
Amsoil
30
40.54%
Redline MT-90
37
50.00%
Stock; you don't need the other crap...
9.46%
Voters: 74. You may not vote on this poll
Amsoil VS Redline MT-90
Old Sep 14, 2006 | 01:44 PM
96mAx2fast's Avatar
Which one should I get for my 4th gen. I have a B&M shifter and I am going to have Jeff @ Maximum Tuning, install a Spec1 clutch kit w/ a Fidanza Flywheel. Which tranny fluid should I get? All opinions welcome!!! Thanks
Old Sep 14, 2006 | 01:50 PM
dgeesaman's Avatar
Maintenance Monster
Shifter doesn't care about the fluid. Fluid doesn't care about the shifter.
If you buy the Amsoil, get the MTG 75w-90. It's a true GL-4.
It's also equivalent to Redline MT-90, which makes this poll kinda pointless.
Dave
Old Sep 14, 2006 | 01:57 PM
96mAx2fast's Avatar
Well, there has got to be some sort of difference. I'm just looking for the smoothest shifting, especially in cold weather. Any input anyone??
Old Sep 14, 2006 | 02:01 PM
dgeesaman's Avatar
Maintenance Monster
Yep, one's made by Amsoil and the other is made by Redline. Pick whichever one you want, and it'll be a little better than dino.
Old Sep 14, 2006 | 03:39 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
im rockin redline and no problems....
Old Sep 14, 2006 | 04:03 PM
Trajiksmax's Avatar
Proud Maxima Owner
I'm using Redline. It's your call.
Old Sep 14, 2006 | 04:32 PM
99se5speed's Avatar
SHIFT_up
I'm using the Amsoil. It's pretty good except i can't take that smell. It's smells like garlic or something horrible!
Old Sep 14, 2006 | 04:50 PM
mtrai760's Avatar
'Trynna' is not a word
Sniffing transmission oil FTMFL
Old Sep 14, 2006 | 04:54 PM
Wrightsfd's Avatar
I'm currently using Mobil1 gear oil (sorry, I forget the weight) and it works very well. Nice feel and smooth shifts. Goes into first gear easier. I disagree with dgeesaman. I notice a different feel with better quality fluid, especially in cold weather. In Chicago winters I couldn't get my previous cars to shift when cold on dyno fluid. Synthetic makes it easier. Not really a concern in SoCal, but there is a more fluid (punn intended) feel to the shifter. Mobil1 is not GL-4 though so some day soon I'll switch to a GL-4. Remember GL-5 is not better simply because it has a higher number. If you can, get a true GL-4.
Old Sep 14, 2006 | 05:04 PM
BlackMaxdout's Avatar
neh, gear oil smells delicious. Then again, I'm an engineer. Oh well. I have used Redline before, but I use amsoil now. The difference between the two is slim to none. I'd say hit up the cheaper one to save some pennies.
Old Sep 14, 2006 | 06:40 PM
dgeesaman's Avatar
Maintenance Monster
I agree with you here - I was saying there is no substantial difference between Amsoil and Redline.
Dave
Old Oct 6, 2006 | 05:54 AM
96mAx2fast's Avatar
Where does the smell come from? can you actually smell it from inside the car???
Old Oct 6, 2006 | 07:38 AM
Blackwind's Avatar
they are almost identical, but i belive amsoil was first. it aint cheap but it's worth it.
Old Oct 6, 2006 | 08:32 AM
dgeesaman's Avatar
Maintenance Monster
The smell of the oil? You can only smell if it the oil leaking. The smell is mostly from the EP additives. The interior of my car smells a little like gear oil, but only because I haul around trannys and tranny parts in my car. You can't smell anything normally.
Dave
Old Oct 6, 2006 | 11:09 AM
Ceasars Chariot's Avatar
Old Maxima Legend
im using redline too, were they selling the stuff these days online. remember the place that had the code discount , dont think they are online anymore, boo
Old Oct 7, 2006 | 10:47 AM
MaxObesset's Avatar
where do you gte amsoil from i have redline mt90 and sometimes its alil ruff to get into gears i want a gear oil that easy to go into gears cold or hot any info would be greatly appreciated thanks
Old Oct 7, 2006 | 12:52 PM
Apparition's Avatar
Ichiban King
yeah I agree, I'd like to find where they're selling it these days.
Old Oct 8, 2006 | 08:58 AM
ethnic6's Avatar
hmmm perhaps its time for me to change my transmission oil?
Old Oct 8, 2006 | 09:10 AM
jac121479's Avatar
i just recently changed over to amsoil from redline...
with redline the shifts are easy and hardly notchy till about 20-30k miles and then it starts to stiffen up, becoming more notchy as time goes on.
with amsoil things are notchy from the start. depending on how short your shifter is, shifting can be alittle more challenging with this fluid.
i've read (in the stickies) the amsoil protects better so i'm sticking with them. hope this helps...
Old Oct 8, 2006 | 09:36 AM
MaxObesset's Avatar
my friend wants to double check he have an lsd trans in his 97 max, could use redline mt 90 gl4 gear oil correct
MaxObesset's Avatar
which one would be better from the start and from 10 15k later have to get changed redline?
Old Oct 8, 2006 | 11:01 AM
ethnic6's Avatar
doubleposting, delete one of ur posts Maxobesset...
wait, do manual transimission even need transmission fluid?
Old Oct 8, 2006 | 03:46 PM
dgeesaman's Avatar
Maintenance Monster
Yes, MT-90 is ideal for that tranny.
Ethnic6, yes, manual transmission use gear oil. It should be changed every 60k or so. If your maxima manual tranny has high mileage I'd suggest even every 30k, since they see so much bearing wear.
Dave
Old Oct 9, 2006 | 06:48 AM
MaxObesset's Avatar
what about lsd limited slip trannys they used a different oil? or the same?
75W90 Gear Oil - the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles; however, other Red Line lubricants have better frictional properties for rapid synchronization. Exceeds API GL-5.
In racing applications, the lighter fluid will allow for less drivetrain power loss, but requires more frequent changes. For racecars doing a lot of high rpm launches, diff abuse or wanting longer change intervals we recommend the Red Line Heavyduty Shockproof Oil.
Old Oct 9, 2006 | 06:49 AM
MaxObesset's Avatar
i was just at a site that sells redlin oil they have 2 types
RED LINE MT-90 is designed to provide excellent protection and improved shiftability for manual transmissions and transaxles. MT-90 has cured the problem of hard shifting in numerous transmissions which have notoriously difficult shifting. The secret to its success is two-fold. First, it has the appropriate coefficient of friction for most manual transmission synchronizers. Many gear oils, engine oils, and ATFs are too slippery for proper synchro engagement. Secondly, the viscosity characteristics of MT-90 allows proper shifting over the entire temperature range which the transmission will experience. The synthetic base oils used have a very high viscosity index which provides relatively constant viscosity as temperature changes. MT-90 is a thicker 75W90 version of MTL. The shear stability and oxidation stability of the MT-90 oil is excellent, thus the physical characteristics will change little with use.
MT-90 is a 75W90 GL-4 and also satisfies motor oil viscosities SAE 10W/15W/40. The additive chemistry used is non-corrosive, so even though they will provide GL-4 performance, they will not corrode synchros or bushings.
Old Oct 9, 2006 | 06:51 AM
MaxObesset's Avatar
this is the site which one u think i should get the differential one for my lsd?
http://marketplace.s2ki.com/s2ki/home.php?cat=24
Old Oct 9, 2006 | 08:08 AM
dgeesaman's Avatar
Maintenance Monster
They use the same oil. I recommend the MT-90.
Old Oct 9, 2006 | 08:56 AM
Apparition's Avatar
Ichiban King
EDIT: should I buy trans drain and fill washers.
Old Oct 9, 2006 | 11:02 AM
ManualMaxima's Avatar
5th Gen till she dies!
i have been using MT90 for about 2 years and i can say i feel 100% no differance at all in how much smoother my shifter has been or anything like it. it feels the same as it always has
Old Oct 9, 2006 | 03:20 PM
RA030726's Avatar
I'm nutty for Nissans
I had Mt90, and switched to MTG. They are both pretty thin, but the amsoil is thinner, at least it pours thinner. I cant comment on feel because I swapped trannies. I have also mixxed mt 90 with MTL (which is thinner) and it was pretty good for cold climates.
Old Oct 9, 2006 | 04:15 PM
Apparition's Avatar
Ichiban King
100% gold ole' placebo effect for most..
Old Oct 9, 2006 | 06:31 PM
dgeesaman's Avatar
Maintenance Monster
I agree. I've tried both, and also Neo 75w-90 HD, and they are basically all the same.
Dave
Old Oct 19, 2006 | 06:58 PM
drewsblackmax's Avatar
kinda late in the thread bu i know what you mean by the horrible smell, when i was trying to find out wtf was wrong with my car, later finding that my transmission blew, all i could smell is that nasty gear oil smell. After a while of it being all over you, you learn to love it.
Old Oct 21, 2006 | 10:11 AM
dgeesaman's Avatar
Maintenance Monster
Were they the exact same temp when you poured them?
I find that the pour of gear oils depends greatly on temperature - if you're doing it on a day where the temp is any less than 70F, it helps greatly to get that oil warm to 70-80F or more.
Dave
Old Oct 22, 2006 | 01:54 PM
acidspit86's Avatar
i love the smell of mt-90 and i will swear by it. i know that immediatly in both my maxs i noticed really smooth shifting, and i was able to downshift into first without too much force at 25mph vs 5mph. now im sure thats hard as hell on the synchros so i dont do it, but thats one thing i noticed
Old Oct 26, 2006 | 07:44 PM
dgeesaman's Avatar
Maintenance Monster
Actually if you take your time pushing into 1st it's not that big of a deal.
Dave
Old Oct 30, 2006 | 03:30 PM
shmad's Avatar
amsoil. when i was on dino oil, it was hard to shift in the winter until the car was driven for about 5-10min. w/ amsoil i could shift smoothly as soon as i took it out the garage.
Old Jan 8, 2007 | 04:40 PM
Sloppy Snood's Avatar
....and this one time, at band camp, I put gear oil on my flute and stuck it up ......
Old Mar 7, 2007 | 07:45 AM
MDeezy's Avatar
changing your shifter bushing > any tranny fluid.
You'll feel a far greater effect.
Old Mar 7, 2007 | 08:35 AM
n2o_matt's Avatar
how do these synthetics compare to the normal gear oil?
I went to autozone and all i could find for GL4 was a bottle of Coastal 75w90 that says API - GL5 GL4 and GL3. How can it be all three? Think its safe?
