Worrying Noise *Vid*
Old Sep 14, 2006 | 08:20 PM
LTU_max's Avatar
Every once in a while I hear this noise coming from where my pedals are. The noise is really hard to listen to because it sounds like grinding or something where it can really hurt the engine. Anyone have any ideas on what this could be?
http://smg.photobucket.com/albums/v6...=Resonance.flv
Old Sep 14, 2006 | 08:24 PM
f550maranello2's Avatar
its the starter.. get it regreased.. or some exhaust component rattling..
Old Sep 14, 2006 | 08:27 PM
matty's Avatar
The cars running man. The starter isnt doing anything
Sounds like an vibrating maybe from the exhaust.
-matt
Old Sep 14, 2006 | 08:31 PM
oh really... too bad that there is a pinion gear turning on the flywheel while the car is running... and it makes the same sound when there is no grease behind it..
http://www.motorvate.ca/mvp.php/516
Old Sep 15, 2006 | 06:51 AM
LTU_max's Avatar
Thanks, I'll try that when I get a chance.
Old Sep 15, 2006 | 08:16 AM
BlackMaxdout's Avatar
yeah, it could be the starter...but I'm going to put my money on a piece of the exhaust being loose. Sounds just like exhaust rattle...makes sense too, you give it some gas, then when RPM's start to fall, you get the noise again.
Old Sep 15, 2006 | 11:55 AM
acidspit86's Avatar
noooooo the starter does NOT ride the flywheel teeth, or even spin, except when starting. when you turn the key forward, the starter solenoid kicks the starter gear over so it contacts the flywheel ring gear, THEN spins the flywheel and retracts to keep from touching the flywheel
Old Sep 15, 2006 | 11:57 AM
MaximaSE96's Avatar
Maxima Owner
BURRRRRRRRRRRRRRRRRRN!!!!!! ^^^^ your right...the only time starter moves is on starting...
Old Sep 15, 2006 | 03:21 PM
most of them have a helical shaft that the pinion gear rides on. Centripetal force throws the pinion to the end where it meshes with the flywheel. Then when it stops, it rides back down the shaft.
Old Sep 15, 2006 | 03:28 PM
Apparition's Avatar
Ichiban King
holy.. thats the sounds mine makes too.. Maxima SE 96 thats the noise mine makes. then it goes away after the car is warm.
Old Sep 15, 2006 | 04:17 PM
Nealoc187's Avatar
SLOW
No, it doesn't. There is no contact between the starter gear and the flywheel except when the starter is actually engaged i.e. you have the key in the "start" position.
Old Sep 15, 2006 | 04:49 PM
Apparition's Avatar
Ichiban King
any ideas what the problem may be Neal?..
Old Sep 15, 2006 | 06:33 PM
WielkiWaac's Avatar
MaximaDriver
did you try open your hood and listen??
Old Sep 15, 2006 | 07:37 PM
sunten1
"Hello, my name is Black Maxima. I am banned until tomorrow so I'm having sunten1 post this for me. I think I have the same problem as LTU_max, it sounds very familiar. After I start my car I hear a whistling/whirling noise coming from the dashboard/firewall area. It's loud and annoying. I cannot tell what is making the noise when I open the hood. The noise still continues after I turn off the air conditioning. If I rev up the engine it still does it. I also notice it at stop lights.
Today, I decided to try to re-grease the starter because of the previous posts. I failed horribly. I couldn't get the starter back together. I ended up buying a starter at AutoZone. I would recommend the starters from AutoZone because they have a lifetime warranty. I still have the problem even after buying a new starter.
I don't know what could be causing the noise. It's been doing it since I got the car over two years ago. It might not do it on very hot days. I only notice it when the engine is cold, or when it's raining. I don't know if that has anything to do with it.
Thanks,
Aaron"
Old Sep 15, 2006 | 08:27 PM
Apparition's Avatar
Ichiban King
Thanks,
Aaron"
yup thats it man.. well you've had it two years, well I'm going to assume then that it's not vital int he least to the cars operation, rather a huge annoyance. I checked everything out under the hood, engine mounts, pulleys, alty, I mean even ridiculous things, inconclusive..
I really am starting think it's something forward exhaust related, or in that general region because it seems to be coming from the firewall area behind the pedals.
Old Sep 15, 2006 | 08:52 PM
Nealoc187's Avatar
SLOW
I just cranked my volume up all the way on my laptop and could barely hear that video, the only thing I think I heard sounded like rattling exhaust heat shields to me... Those things are all over the place on this car and th little 10mm bolts that hold them on rust away and break, letting them rattle around quite often. That's the only thing I thought I heard.
Old Sep 15, 2006 | 10:40 PM
Apparition's Avatar
Ichiban King
hmm..
(haha random though btw.. you at the track, laptop in car, typing this comment before you take a run in the 1/4.)
Old Sep 16, 2006 | 06:23 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
you have no idea what your saying take a basic auto mechanics course please.
Old Sep 16, 2006 | 01:19 PM
Scruit's Avatar
U wanna try me young boy?
I regreased the starter in my car about 2 years ago. The problem I was having was the starter woudn't engage with the flywheel and instead would make that same grinding noise you get when you accidentally try to start a car that is already running.
Sounds like something big that is in contact with the exhaust. The sound is a little too deep for a heat shield (which is usually a tinny sound). I would check the exhaust from front to back and make sure it's not touching up against anything.
The sound is low pitched and muffled. Sounds like it's touching a large piece of metal that is damped by something. Possibly touching the floor pan??
Old Sep 16, 2006 | 01:49 PM
LTU_max's Avatar
Also when I hear the sound, my gas pedal seems to vibrate with it.
Old Sep 16, 2006 | 01:51 PM
Apparition's Avatar
Ichiban King
yeah we share that terrible vibration..
Old Sep 16, 2006 | 05:15 PM
Black Maxima
Yea, I think my pedal vibrates too.
Old Sep 16, 2006 | 05:19 PM
njmaxseltd's Avatar
That noise is coming from the tranny. It's a dry bearing spinning.
Release bearing, input shaft bearing, clutch assembly, something in there.
Old Sep 16, 2006 | 05:39 PM
Apparition's Avatar
Ichiban King
well.. it only does it around 1k until the car warms up.. I thought a bearing would constantly groan or w/e.
Old Sep 16, 2006 | 07:52 PM
Black Maxima
What about with an automatic transmission?
Old Sep 16, 2006 | 09:06 PM
Scruit's Avatar
If it's a stick then trypushing the clutch in a tiny bit, see if the noise goes away.
I had a bad input shaft bearing that was noisy when the trans was in neutral and my foot was off the clutch. Pressing the clutch pedal in a little put enough side-load on the shaft that it didn't rattle any more.
Old Sep 16, 2006 | 10:36 PM
Apparition's Avatar
Ichiban King
(GASP) Black Maxima..
Old Sep 17, 2006 | 06:40 AM
Black Maxima
So maybe it's not the same noise? It does sound pretty similar to mine.
Old Sep 17, 2006 | 06:41 AM
ddurandd's Avatar
I also have this same groaning noise on my 96 automatic. It started about 2 years ago, but it goes away after the engine warms up. I have never been able to track it down, but I haven't noticed any other adverse problems related to it. I would sure love to know what is causing it.
Old Sep 17, 2006 | 09:53 AM
Apparition's Avatar
Ichiban King
Okay so we can pretty much conclude its something retarded causing it.. not something vital. So, I think that I may just say screw it and wait until something happens, which it sounds like it never will.
Old Sep 17, 2006 | 01:11 PM
heynow's Avatar
same thing on a '97 GLE
I'm getting the same noise on my '97 (AUTO). I tried listening to it with an open hood, and i can't figure out where it's coming from. It happens only on a cold start after the car has been sitting outside overnight. It usually goes away after it gets to 1,000rpm. I just let it idle for like a minute and just start driving.
Old Sep 17, 2006 | 02:44 PM
Apparition's Avatar
Ichiban King
well seeing as you AT guys are having the same problem.. I'm going to assume its more somethign we have in common which is obvious. Something exhaust or mount related..possibly.
Old Sep 17, 2006 | 06:12 PM
WHAT THE GAY!!!!! I DIDNT WRITE THAT GARBAGE, MAN WTF!!!
Danny u bastard, i catch you again using my screen name im gonna stab you...
How the crap is a starter gonna gear gonna spin while the flywheel is turning, that gear would be spinning at like 30k rpm!!!
Old Sep 18, 2006 | 06:56 AM
heynow's Avatar
Can anybody shed some light on this issue? It's really annoing hearing that whine every morning
Old Sep 18, 2006 | 08:07 AM
HomerMAC's Avatar
Donating i30 Owner
AHHH HUH...
Old Sep 20, 2006 | 01:33 PM
LTU_max's Avatar
Anyone have any other suggestions?
Old Sep 20, 2006 | 01:54 PM
Black Maxima
Yea, I need to know what this is. Maybe this weekend I will take another video of it.
Old Sep 21, 2006 | 04:55 PM
heynow's Avatar
go ahead dude, maybe we can figure this out.
Old Sep 30, 2006 | 07:40 PM
heynow's Avatar
Could anybody shed some light on this issue?
Old Sep 30, 2006 | 09:09 PM
Black Maxima
Bump!!!!!!!!!!!!
