burning oil
Old Sep 15, 2006 | 02:58 PM
maxgp1029's Avatar
00vi Equipped.......
burning oil
This is the second time now. About 2 months ago my oil light would flash on and off as my a rpms would drop off below 1000 in nuetral. When the rpms would rise back up it would stay off. So I change my oil (the last time i changed it before that was another 2 months) and apprx a quart came out. On top of it i only drove 2400 miles. It just started flashing again and i drove about the same amount of miles. Any ideas?
Old Sep 15, 2006 | 05:44 PM
moogotzskillz2's Avatar
how many miles do u have on the car, and what oil and wight do u use? i heard if u use the thinner oil on a high mileage car it makes the light come on so, i'd look in too it before drivin it, cuzz u can blow ur motor if u need a oil pump.
Old Sep 15, 2006 | 06:36 PM
maxgp1029's Avatar
but im burning oil hence why only a quart came out when i changed it.
Old Sep 16, 2006 | 07:16 AM
nismology's Avatar
What makes you so sure it's not a leak?
Old Sep 17, 2006 | 04:36 PM
maxgp1029's Avatar
not leaking any oil, i park my car in the same spot every nite and let the car warm up in the mornings.
Old Sep 17, 2006 | 04:42 PM
njmaxseltd's Avatar
Originally Posted by maxgp1029
So I change my oil and apprx a quart came out. On top of it i only drove 2400 miles.
If your engine was burning 3.5 quarts of oil in 2400 miles you would see the smoke coming out of your tailpipe.
I call on your oil consumption theory.
Old Sep 17, 2006 | 05:09 PM
maxgp1029's Avatar
^^kewl dude....
Old Sep 17, 2006 | 06:16 PM
f550maranello2's Avatar
Not always, my friends cadillac would burn about 2.5 quarts in like a month... u never saw smoke it just consumned.. also my cousins passat, with 30k miles did the same thing except u it burned all the oil and the motor siezed
Old Sep 17, 2006 | 06:24 PM
99Maxxx's Avatar
I had a similar problem...mine would run fine for about 2 months nad then would smoke like a freight train and idle rough until I changed plugs and I ended up having to put spark plug tube seals in it
Old Sep 17, 2006 | 06:29 PM
check your compression.... to make sure
Old Sep 17, 2006 | 07:45 PM
96blkonblkse's Avatar
if your burning that much oil in that short of a time period either A. your leaking oil and not noticeing it, or B. your burning oil like crazy. do you notice any smoke out of the tail pipe on start up or under heavy load? another thing is by the time the low oil pressure warning light comes in most cases its already to late.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
