axle seal question
It's a little bit of a pain. I pulled out the axle when I had the exhaust off. I dunno if you can get to the bolts on the bracket without taking off the y-pipe. After that just pry out old seal and push in new one. Grease it up good and put the axle back in. Be carefull with the new seal, it's a little fragile.
Well I suppose it's better to tell you now rather than later...
Some oil leaks are caused by damaged seals. Others are caused by damaged transmission bearings. There are very many manual trannys with partly or really damaged bearings.
Start by changing both axle seals, but while you're down there and before you pull the axles, grab the big round (rusty) part of the axle by the tranny and see if you can find any up/down/forward/backward wiggle room. Any at all - it will be small if it's there. If you find that, expect that the seal replacement won't work. Unfortunately the best time to diagnose and fix the bearings is when the tranny is out of the car, so it would have been nice to know about that before making the swap. I hope you just have a nicked seal.
In any case, make sure there is enough gear oil in the tranny. Running low on oil will quickly destroy the good stuff inside.
Dave
Dave
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
to that
