Service Engine light pissing me off
Sep 16, 2006 | 04:48 PM
ok, well I got my KS fixed finally... diagnosed the ECU, got a 0505 - No problems detected... and reset my ECU, all is fine until I had to drive it, at first it was ok, no lights nothing, but soon enough the engine light started to blink, keeps blinking continuously. What do I do guys reset it again or is this something more?
Sep 16, 2006 | 05:00 PM
Blinking/flashing CEL = misfire, read the stickies
Sep 16, 2006 | 05:02 PM
It sounds like you have a different problem now.
Sep 16, 2006 | 05:03 PM
Ya think
Sep 16, 2006 | 05:14 PM
mine's been like that for a while know and there def isnt a misfire, the car runs smooth and no sputtering. i havent fixed it either, its a bad o2 and a ks, i really dont drive the car so i havent gotten to fix it, but how excatly can you go from resetting codes to the car misfiring? in a matter of minutes
Sep 16, 2006 | 05:18 PM
but there is no codes comming up about a misfire... so right now I don't know what the problem is it just keeps blinking in slow sequences of 2s...
Sep 16, 2006 | 05:19 PM
Quote: mine's been like that for a while know and there def isnt a misfire, the car runs smooth and no sputtering. i havent fixed it either, its a bad o2 and a ks, i really dont drive the car so i havent gotten to fix it, but how excatly can you go from resetting codes to the car misfiring? in a matter of minutes
ya my car actually feels more powerful now that my KS has been replaced. if it was a bad o2, then how come it didn't come up in the ECU test?
Sep 16, 2006 | 05:24 PM
Quote: ya my car actually feels more powerful now that my KS has been replaced. if it was a bad o2, then how come it didn't come up in the ECU test?
mine blinks the way a diag scanner reads o2 readings, it flashes quick during heavy accel and slow during coasting to show rich/lean conditions. i have no idea why it's doing it, i just havent gotten around to fix the known problems to try to fix that.
Sep 16, 2006 | 05:38 PM
so there is a way to fix it? how do u fix it?
Sep 16, 2006 | 06:04 PM
did u reset the ECU with the screw...cause if u did ur prolly still in diagnostic mode....if not then misfire
Sep 16, 2006 | 06:19 PM
Quote: did u reset the ECU with the screw...cause if u did ur prolly still in diagnostic mode....if not then misfire
yup I reset it with a screw, and turned the car on again and the SEL was off, it didn't start blinking until after I was on the road again.
Sep 17, 2006 | 08:57 AM
ahhh someone help me! I can't stand it! its not a misfire! but it keeps BLINKING!!!
I just did another ECU test, and it came out the same codes 0505, so no misfiring, if it is misfiring it would give me the code for which cylinder... so I seriously need help, doesn't anyone know how to fix this?!?!
think I should bring it to a dealership? because the stickies can't answer it...
