Another oovi question.....
Old Sep 17, 2006 | 05:11 PM
maxgp1029's Avatar
00vi Equipped.......
Any body on the org no where to go to find a complete oovi installation. Everything that i find on the org is just bits and pieces.
Old Sep 17, 2006 | 05:18 PM
chillin014's Avatar
i dont even know what an oovi is.
(00vi)
there is no write up, read. learn.
Dark99GLE's Avatar
just wait for one, they'll show up
Old Sep 17, 2006 | 05:38 PM
Cdg2125's Avatar
Keep looking. A lot of guys have done this so they would have the entire list of stuff. Tatanko has a website that has the whole list and pictures of stuff. Ceasars also posted a whole mess of pictures for the process. There is no write up so you have to search and figure out what to do.
Old Sep 17, 2006 | 06:05 PM
Tatanko's Avatar
Bacon Lover
http://away.no-ip.org/maxima
http://pg.photos.yahoo.com/ph/ceasar...riot/my_photos
Soon enough there will be one
You DEFINITELY need to search, though.
Old Sep 17, 2006 | 06:25 PM
f550maranello2's Avatar
^^^^^ thanks man u did a great write up... it should be stickied
Old Sep 17, 2006 | 06:36 PM
99Maxxx's Avatar
I still have onequestion about this...I tried the setup with the 00 upper and 4th gen everything else and the thing would not idle. I'm not sure that it can be done with the 4th gen TB
Old Sep 17, 2006 | 06:39 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
^yes it can.
Old Sep 17, 2006 | 06:40 PM
Cdg2125's Avatar
Id say go for the 2000 or PF throttel body anyways. You're upgrading the intake manifolds so you should get a bigger TB as well right? Just my thoughts.
Old Sep 17, 2006 | 06:55 PM
chillin014's Avatar
you had an adaptor plate?
Old Sep 17, 2006 | 07:14 PM
Tatanko's Avatar
Bacon Lover
It has been and is the most common setup.
It's not really any bigger, actually.
Old Sep 17, 2006 | 07:38 PM
Cdg2125's Avatar
Ok I apologize. So it's not worth it to use the 2000 or PF?
Old Sep 17, 2006 | 07:52 PM
Tatanko's Avatar
Bacon Lover
2000, not really. Pathfinder, yes, it's much larger than the 4th gen TB (70mm vs. 60mm).
Old Sep 18, 2006 | 03:00 PM
99Maxxx's Avatar
ok, so give me a clue as to why it wouldn't idle...i want to say i tried it with the 5th TB and 4th IAC but I even tried it with the 5th IAC and still had teh same result - a steady lope between 1500-2500
Old Sep 18, 2006 | 03:19 PM
Tatanko's Avatar
Bacon Lover
I don't know enough about that particular combination to tell you, really. Lots of things can be done incorrectly, though, that would result in that regardless of what combination you used.
Old Sep 18, 2006 | 03:26 PM
Curt's Avatar
00vi
It can, and it's really pretty simple if you don't screw it up. And it works like a charm..... mine does!
Old Sep 19, 2006 | 03:40 AM
maxgp1029's Avatar
oh i've been searching. Its just I've been getting little bits and pieces from each thread. I got all 5th gen parts uim lim fuel rail injectors, throttle body, I'm still trien to find a used valve cover though. But yea ill start the install at the end of the month when i get my beater truck. Still lots of time for research...
Old Sep 21, 2006 | 11:06 AM
maxgp1029's Avatar
.....the parts are in
Old Sep 21, 2006 | 04:03 PM
99Maxxx's Avatar
So you did use nothing but the 5th upper and 4th everything else?
rizzindriver89
Aug 18, 2010 10:23 AM
96nismomaxi
Nov 13, 2005 06:39 PM
VQ30de96
Oct 6, 2005 08:35 AM
shvelle
Jul 27, 2004 06:29 AM
