cylinder 6 misfire??
Old Sep 23, 2006 | 09:19 AM
babymac's Avatar
BOOST 4 LIFE!
I just got a code 0603 which means cylinder 6 misfire. Would that be the injector or something else?? Pleaee help this car is runnuing like $hit! Thanks.
Old Sep 23, 2006 | 09:36 AM
willard00's Avatar
i hear injectors are not common failures. my guess would be coils. when my coils were bad the car would kind of stutter and the rpm's would drop a bit then jump back up. then i got a cylinder misfire code.
Old Sep 23, 2006 | 09:56 AM
babymac's Avatar
BOOST 4 LIFE!
I just had a injector fail about two months ago same exact problem as now. I had a coil fail whole different feeling. My rpm's say steady thats why I know its not a coil.
Thanks anyway.
Old Sep 23, 2006 | 10:00 AM
willard00's Avatar
so then why post and ask for help?
Old Sep 23, 2006 | 10:22 AM
babymac's Avatar
BOOST 4 LIFE!
Because smart@ss I just figured it out!
Old Sep 23, 2006 | 01:08 PM
Fork's Avatar
Maximaler Experte
I just pulled this code (threw the ECU into diao) and 06-03 came up but no CEL. I have NGK G-Pwr plugs - gonna swap them out for the Iridium-IX anyways. Car idles pretty bad but acceleration is silky smooth.
FRAC, INJECTORS! What causes an injector to go? Aren't they suppose to last the life of the car?
Old Sep 23, 2006 | 05:12 PM
babymac's Avatar
BOOST 4 LIFE!
well changed the injector and now the car won't start?? It just clicks and thats it. I am thinking that it is the starter because it smells like it is burning when I try to crank it becuase it does crank at all.The battery is a optima red top and is fine....... I don't know? Gonna have it towed and let the mechanic figure it out because I'm done with this B.S!!
Old Sep 23, 2006 | 09:27 PM
MrDicks95SE's Avatar
Offset Is Everything.
injectors dont last as long as the car. possibly due to carbon buildup, dirt, bad wiring, or just plain failure. and injectors are quite a common problem but not as common as the coilpacks.
Old Sep 24, 2006 | 08:29 AM
dovetailguy's Avatar
Fuel Injector
I had the same thing happen to my car. I changed out all the plugs and I thought it might have been a blown head gasket, but it turned out to be a bad fuel injector..THANK GOD........... was about $150 to fix it.
Old Sep 24, 2006 | 11:49 AM
babymac's Avatar
BOOST 4 LIFE!
update decided to change the starter myself with a remanufactured bosch 10 tooth starter and cross my fingers. I still have a 8 tooth so I should change it anyway.
Old Sep 25, 2006 | 08:36 AM
wlaukaitis's Avatar
swap the suspected coil with another cylinder and see if the cylinder you swap with gets the code.
Old Sep 25, 2006 | 09:34 AM
babymac's Avatar
BOOST 4 LIFE!
Changed the starter and still no start a different sound, but no start so I had it towed to a friends shop to see if he can figure it out. Hopefully it won't cost to much..
Old Sep 25, 2006 | 01:18 PM
babymac's Avatar
BOOST 4 LIFE!
There telling me that the motor is flooded with to much fuel ,so it win't start till it is drained out?? I never heard of this , so who knows I don't think they know what they are doing.....
Old Sep 25, 2006 | 02:32 PM
matrix11229's Avatar
Take the #6 spark plug out and the nearby plug, see if they have different gap, and check the gap with a gapping tool. Probably you will find the ground electrode bent.
Old Sep 25, 2006 | 05:19 PM
babymac's Avatar
BOOST 4 LIFE!
Got the car back and its worst then ever now its smoking and smeeliing like fuel bad! So brought it back and we will see what happens tomorrow. I just gotta have patience and just deal with it.....
Old Sep 25, 2006 | 05:22 PM
babymac's Avatar
BOOST 4 LIFE!
I checked the gap and it was perfect but the plug was BLACK. The car is just running ridiculously RICH. I think one of the injectors is just dumping fuel??
Old Sep 25, 2006 | 08:22 PM
Read this :
http://www.ngksparkplugs.com/techinf...200&country=US
Old Sep 26, 2006 | 08:26 AM
babymac's Avatar
BOOST 4 LIFE!
I know the plugs need to be changed now , but the dumping of fuel must be fixed first or it is just going to keep fouling them. This really sucks the csr was running so good too
Old Sep 26, 2006 | 08:55 AM
MaximaSE96's Avatar
Maxima Owner
injector time.
Old Sep 27, 2006 | 02:34 AM
babymac's Avatar
BOOST 4 LIFE!
The injector was changed?? I think the bad one flooded the motor.......... I hope, unless another went bad. This whole ordeal just sucks! I just want my car back.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
