How does an exhaust leak effect performance?
Old Jun 27, 2001 | 10:22 AM
ejj's Avatar
ejj
I have a leak in the flex section of my y-pipe (its the old Jet-Hot kind, so I new it would happen...I've already ordered a Cattman SS one...).
How will this effect performance? The power in the car does not quite feel as even as it normally does...and that little dip in torque that 4th gens have seems to be more noticable.
I am going to the track tonight...will this leak hurt my times?
Also, the leak buzzes when I start the car..really bad! But after driving for 5 minutes, when the exhaust heats up, it gets much, much quiter. Don't know if that makes a difference.
Old Jun 27, 2001 | 10:47 AM
TJ's Avatar
TJ
Your low end will be hurt. I have a small leak myself on the back end of my muffler. There is a little bit of lag or hesitation when I take off somtimes. I'm having my muffler shop fix the weld next week. Why not just have the flex section repaired instead of spending all that money on a new Y-pipe.
Old Jun 27, 2001 | 10:55 AM
ejj's Avatar
ejj
Well, I've been wanting a Stainless Y-pipe for a while now. The wonderful Rochester/Buffalo winters are killing the steel exhaust that is down there now.
Old Jun 27, 2001 | 11:23 AM
TJ's Avatar
TJ
Water and salt do tend to have a taste for metal. If I were you, I would not do the track thing untill the new Y-pipe is installed. Unless you want to see the difference in times between a leaky Y-pipe and a non leaky Y-pipe. You could have a muffler shop fix it before you race. It shouldn't cost you no more than about $50 to fix.
Old Jun 27, 2001 | 11:28 AM
ejj's Avatar
ejj
Why wouldn't you race? Yeah, my times won't be as good, but there isn't really any harm to be done, right?
Old Jun 27, 2001 | 11:37 AM
Jeff92se's Avatar
I'm needing a caw
My Jet-Hot Cattman flex section leaked also. I think it hurt the low end but it mostly made horrible noises. But instead of ordering a new Y, I just had a good shop cut and weld in a new QUALITY flex section(ie.. lined). It helped reduce the noise SIGNIFICANTLY.
Old Jun 28, 2001 | 12:38 AM
vmok's Avatar
is the leak the 'hissing' sound that you hear from the exhaust above 3000 rpm when you get on the throttle hard?
if not, what is the hissing sound? not that I don't like it, i think it actually sounds good...
-V
Old Jun 28, 2001 | 03:13 AM
party_boy's Avatar
DUCT TAPE
as the wise trailer trash hick said...it fixes everything....
and try to keep some ventilation...dont die from carbon monoxide poisning
Old Jun 28, 2001 | 06:42 AM
Sonic's Avatar
Re: DUCT TAPE
Uh, duct tape would melt(I'm only saying this because I didn't see the smilie at the end of the comment).
Old Jun 28, 2001 | 06:47 AM
ejj's Avatar
ejj
Re: Re: DUCT TAPE
Ha ha, someone actcually suggested that I use duct tape last night at the track. I thought he was kidding, but now I'm not so sure.
Well, I did run at the track last night, and my times sucked, I feel mainly in part to the exhaust leak. I couldn't get a 60' time less than 2.3. Overall my times where about .3s slower than my previous times.
Guess that answers my questions about performance
Old Jun 28, 2001 | 10:54 AM
Dave B's Avatar
Not DAVEB the parts guy
An exhaust leak won't affect performance that much. The reason you are seeing a .3 slower et is because of the heat. In March and April I was running 14.7/14.8@94 and now I'm running 14.9/15.1@92. The difference is the weather. My best ets were in 50 degree dry weather and now it's 80+ degree humid weather. Heat and humidity suck a ton of life out of the motor. Take a look at your timeslips. I can almost assure you that a majority of your et is lost in the first 1/8th. In hot weather, my car is .3 slower to the 660' vs cooler weather. Your 60 foots are slow because you aren't making as much torque.
Also, you describe a rattley noise on startup. That's not your y-pipe. That's the RT cat. Nearly every RT cat (including mine) has this problem. The bricks become loose in the housing. Once the bricks expand on warmup, the rattle goes away.
Dave
Old Jun 28, 2001 | 11:09 AM
ejj's Avatar
ejj
Dave
I know the RT cat rattle that you're talking about (I have it too), and this is not it. Its more of a buzzing...that and I've gotten under the car and felt the exhaust leaking from the y-pipe
As far as times...I don't think the weather made the entire difference. At the end of the night, it was only around 60-65 out. It wasn't really that warm. I think if the exhaust was in better shape, I think I could have run high 14.8's.
Like I said in my other post, I figure I was running mid to high 14.9's most of the night, but I was backing off at the line to make sure I didn't break out. That and I only dialed a 14.99 because in my first two runs my best was a 15 flat.
Old Jun 28, 2001 | 03:56 PM
got rice?'s Avatar
It depends on how big the leak is. A pinhole leak won't affect it all that much but if it's larger than a few millimeters it'll disrupt the flow. The key to a good exhaust is the least amount of turbulence to keep the exhaust gas velocity high. An exhaust leak will cause the flow to become turbulent since the exhaust gas will want to flow out of the hole and not the rest of the piping (bad for low end flow). You can wrap it with exhaust piping tape which should withstand the higher temps better than duct tape.
Old Jun 29, 2001 | 07:00 AM
ejj's Avatar
ejj
Turbulence is a good word for my exhaust flow now. Acceleration and power feel a lot less even, and a lot less smooth then normally.
Thanks.
Old Jun 29, 2001 | 08:28 AM
caneyebus's Avatar
EXHAUST LEAK
i had a cracked y pipe..and this is what happend
1. Lost pressure always had the pedal to the floor
2. NO hp..i think i was at bout 170hp
3. There was an annoying sound similar to a snoring person
4. got left by winnebagos!!
5. Had exhaust fumes everwhere (i.e. inside the car)
6. Couldnt get a date
But thats me. I had a cracked stock pipe.. I upgraded to a Cattman y-pipe cause nissan wanted 7 bills for a new stock one...
Old Jun 29, 2001 | 08:42 AM
fnkmaster's Avatar
Re: EXHAUST LEAK
why does sound sooo familiar? i found out the same thing when i was installing my exhaust... damn nissan... oh well, better for less, why not!?
Old Jul 2, 2001 | 05:18 AM
caneyebus's Avatar
EXHAUST LEAK
oh i guess nissan must just wanna jerk cats..
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
carid
Sep 9, 2015 05:06 AM
Justin Kroll
Sep 2, 2015 11:06 AM
