Code 0504 Help
Old Sep 25, 2006 | 01:16 AM
AussieA32's Avatar
Code 0504 Help
Hey everyone,
OK I just did my diagnosis and 0504 popped up now has anyone had problems with this code and how did you fix it. After reading the engine code thread I have already replaced my auto computer and Im still deciding weather to replace the battery. Would it just be easier taking it to an auto electrician and letting them sort it out? Also the knock sensor code came up what does this do and what do I do about it.
Old Sep 25, 2006 | 03:49 PM
Digitized's Avatar
Well, according to the code 0504, it's :
This malfunction is detected when the ECM continuously receives an incorrect voltage from the TCM. Possible causes include...
- Harness or connectors (The communications line circuit between the ECM and the TCM is open or shorted.)
- TCM
- Discharged or faulty battery
Therefore, if you did the TCM and the ECu, next would be check the wire harness and check you battery voltage..
as for the knock Sensor code ( I assume you are getting code 0304), simply replace it...
0304
Diagnostic Trouble Code 0304 points to a problem with the Knock Sensor. The KS is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is senses as vibrational pressure. This pressure is converted into a voltage signal and sent to the Engine Control Module (The computer).
This malfunction is detected when an excessively high or low voltage from the KS is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS. However, I think that a person with good dexterity and a 12mm ratcheting box wrench could replace the KS without disturbing the manifold.
I was able to change the knock sensor without removing the intake manifold.
if you need pics, go here: http://www.motorvate.ca/mvp.php/507
Old Sep 29, 2006 | 12:19 AM
AussieA32's Avatar
Kool bananas. Ok question about the battery it is brand new and it was discharged once and jump started once can this be the cause of all my trouble?
Old Oct 17, 2006 | 12:17 AM
AussieA32's Avatar
Please Im desperate anyone can they help 3rd wont hold out forever!
Old Oct 17, 2006 | 10:23 AM
Ward's Avatar
Same Code as you, if you get the problem solved, pls give me a pm
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
