vibration..help
Old Sep 27, 2006 | 01:08 PM
skweaky's Avatar
vibration..help
since i bought my 98 SE it has vibrated when accelerating from 25 to 30 mph. it doesnt matter what gear but it does it more in 2nd. any easy fixes or is a tranny/cv issue?
Old Sep 27, 2006 | 01:28 PM
wetzelman1's Avatar
I've heard it's an injector problem. My car started doing this recently and I'm trying to remedy the problem as well. I just got a new knock sensor and am waiting to install it but I've heard that could be the source as well.
Old Sep 27, 2006 | 01:36 PM
skweaky's Avatar
just put in knock sensor monday... not it. i thinks its drive train because it a speed issue and not a rpm issue. but the knock sensor is a good buy, night and day diff but not on the vibration
Old Sep 27, 2006 | 02:58 PM
NYC_Maxima97's Avatar
What kind of vibration is it? Is it an engine, tranny vibration or more of a chasis/wheels type of stuff?
Old Sep 27, 2006 | 04:32 PM
skweaky's Avatar
i really dont know. thats what im asking. i can feel it alot in the steering wheel.
Old Sep 27, 2006 | 05:40 PM
MDeezy's Avatar
Try to break it down for us more.
At what speeds does it vibrate/vibrate more
In certain gears?
Only when braking?
only when turning?
Whats your tire pressure?
Have you gotten an alignment recently?
When last were your inner/outer tie rods replaced?
Old Sep 27, 2006 | 06:15 PM
Apparition's Avatar
Ichiban King
In certain gears?
Only when braking?
only when turning?
somehow I think he's a victim of tire balancing/alignment..
Old Sep 27, 2006 | 06:26 PM
MDeezy's Avatar
I bet you a bad alignment
Old Sep 27, 2006 | 07:22 PM
beefy23b/97's Avatar
jack up your car and secure it on stands, then turn on your car and put it in D. if your wheels are unbalanced you will be able to see the wheels shaking
Old Sep 28, 2006 | 05:33 PM
skweaky's Avatar
its got brand new kuhmo ecstas and i got my allianment done and the tireds balence twice after i pu them on and it sitll did it. and as i said befor its in any gear fron about 25 -30 and i feel it through the steering wheel. it did it just as bad now as it did befor i lowered it so i know its not that. i was thinkin maybe c/v's.not sure how to check.
Old Sep 28, 2006 | 05:35 PM
skweaky's Avatar
the only thinkg i know about checkin c/vs is to listen for poopping when turning and to also just reach under there and feel for slack. no popping out of em....but when i wiggle them theres no slack either. when i turn them there is a little play on the tranny side but not much.
Old Sep 28, 2006 | 05:46 PM
heynow's Avatar
check control arm bushings as well? oR wheel bearings?
Old Sep 28, 2006 | 07:09 PM
skweaky's Avatar
i checkes wheel beringss. i jacked the car up and even tugged on the tire and no play at all. i also cranked the car and eased of the clutch with it in the air. no woble i just dont get what the shake is. i may need rotors but they arent that bad. just alittle shaky under braking
Old Sep 28, 2006 | 08:08 PM
heynow's Avatar
if it's just shaky under braking, then it's he rotors
Old Sep 29, 2006 | 01:34 PM
Jaydigital's Avatar
I don't know if you have aftermarket wheels, it could be the wheels don't fit correctly. Might be right bolt pattern, but you could need to add concentric rings under the wheels to fill any gaps between the wheel and the axle. that's the problem I had, and the rings made a huge difference. smooth as Crisco on a slip'n'slide now.
