Cefiro Hardware
Old Sep 28, 2006 | 08:54 AM
Rick James's Avatar
Cefiro Hardware
To install the cefiro headlights do you need the black plastic that the OEM lights sit in to aim them?
How is the light out put over the blacked out ones on ebay?
Old Sep 28, 2006 | 09:40 AM
Dubbya's Avatar
VK56 Inside
You dont use any of the stock peices except the wires for the light bulbs. H4 > 9004 EVERY day of the week. There really isnt a comparison.
Old Sep 28, 2006 | 09:58 AM
MrDicks95SE's Avatar
Offset Is Everything.
no you dont need that black mount for the oe headlights. take out everything. i had the "smoked" housing for a while, it looked great and output was much better than stock. then again, i was running HIDs on the Cefiros. i went back to stock after a front end accident. didnt like the fitment issue. good luck with the installation...
Old Sep 29, 2006 | 04:16 AM
Rick James's Avatar
Does anyone have an engine bay pic of the cefiro's installed.
Old Sep 29, 2006 | 03:00 PM
shavedmax's Avatar
the bolt right into place after you cut out the fender support for the oem headlight and bent the end of the radiator support in the same spot. dont really need a picture of that
Old Oct 24, 2006 | 06:24 PM
kbz504's Avatar
I bought the clear Cerfiro one pieces off ebay and put them on my I30. They fit pretty good. However I couldn't see jack at night. I tried over and over to align the beams..even took it to the dealer. I winded up going back to stock...I wasted my money. Hopefully you have better luck.
Old Oct 24, 2006 | 11:15 PM
retrospex's Avatar
i've had a previous front-end collision, but things appear to be in 'normal' condition -i could be wrong, what should i be concerned with if i want to put cefiros in?
Old Oct 25, 2006 | 05:57 AM
sergey85's Avatar
i think their are different makers of the cefiro some bad and some better i had a pair from ebay on my old car and the pattern was pretty bad and didnt really light up lot of the road unless really dark. but hid would probably solve that
Old Oct 26, 2006 | 02:53 PM
jjamzman's Avatar
The only bulb that works properly in the Cefiros is the H4. You can fit the stock 9004s and others into the light housings but they don't align properly with the Cefiro internal reflectors. I know, I did it. The 9004s vs. the H4s - you go from not seeing anything and not being able to adjust the patterns to a bright flat pattern that adjusts just fine. With the H4 bulbs, the lights are better than stock.
jjam
RinconI30
Jun 11, 2016 08:25 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RinconI30
Nov 10, 2015 10:55 PM
alphakaoz
Sep 30, 2015 07:33 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
