Idle problem on a 98 5spd
Old Sep 29, 2006 | 10:46 AM
DuMKuH's Avatar
Hey guys, I have a 98 5spd maxima, and lately, my idle became too high, I mean usually its 600 but now its like 800. The IACV has been cleaned, new NGK spark plugs, all service, everything has been done properly. I have been trying to tune it using IACV regulator bolt(Turned off TPS, started, tuned, connect back, started again), but as soon as I start it after connecting TPS back, it comes back to 750-800. No CELs. Thank you. ANyhelp is appreceated.
Old Sep 29, 2006 | 01:32 PM
DuMKuH's Avatar
Anyone ?
Old Sep 29, 2006 | 01:57 PM
2muchbass's Avatar
waits for da goon squad to come preachin bout donating to search
Old Sep 29, 2006 | 01:59 PM
2muchbass's Avatar
dumkah u are not alone im havin the same problem with my 95 5spd
Old Sep 29, 2006 | 03:32 PM
jasonv's Avatar
..... bad tps?
Old Sep 29, 2006 | 03:43 PM
DuMKuH's Avatar
Thanks,is there a way to check it?
Old Sep 29, 2006 | 05:04 PM
njmaxseltd's Avatar
From the Haynes shop manual
PCM control of the idle system must be disabled before checking or adjusting the idle speed.
Place the ECU in self diagnostic mode, code 0505 should be flashing indicating no trouble codes are present. If trouble codes are present, repair the problem before proceeding.
Idle speed adjustment, done with the engine completely warmed up:
Place the ECU in self diagnostic mode (code 0505 flashing) and start the vehicle. Adjust the idle speed using the bypass screw located near the IACV.
Idle speeds are as follows:
1995 -
Manual tranny - 550 - 650 RPMs
Auto tranny - 600 - 700 in park
1996 - 1999
Manual tranny - 525 - 625
Once the idle speed is set, turn the engine off.
Idle speed is set with a completely warmed up engine, no A/C headlights or any other accessories on.
Old Sep 29, 2006 | 10:54 PM
DuMKuH's Avatar
Thatnks a lot! I do have a code(knock sensor). So i'll try it as soon as I get done.
Old Sep 30, 2006 | 12:56 PM
maximaintheface's Avatar
i have the same problem with my 96 a/t i tired changing it with the ecu in that mode still didnt work. changed my whole thorttle body and tps. changed iacv. checked for a leak checked just abut everything i could check still having the issue. but im idling at 1000 and i can get it in the right range but once i plug the tps in it goes right back up.
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
