cf hood issue involving wiperfluid nozzels
Old Sep 30, 2006 | 09:11 PM
maximaSE327's Avatar
how did people w/ cf hoods get the wiperfluid nozzels on... i had a shop do it but he said he didnt think it was possible and didnt wanna ruin my hood... are there aftermarket nozzels that will work??? i need to get these in before the winter... help is appreciated, thank you!
Old Oct 1, 2006 | 02:20 AM
battlestylespl's Avatar
is it a factore of not being able to get the hose on underneather or the nozzle just wont fit in the holes on top?
on my 240sx i had to use a hole saw on the bottom just so i had access to get the damn hoses on. they fit fine on top. but...it that seems to be your problem...get a dremel tool with a small bit that is covered in the sandpaper and reem the hole out to where it looks like the holes on the oe hood. that should be easy enough for a novice. i myself would prolly use a die grinder though with small bit.
Old Oct 1, 2006 | 04:05 AM
glenmoormax's Avatar
10 psi
A while back i helped another maxima guy do this, we just ended up not using them, I havn't seen him for a while now but I don't think he ever installed them, I an sure you could just drill your hood a little more to fit t hem in there, but that would make me nervous if it were my hood.
Old Oct 1, 2006 | 07:21 AM
MAXSE5SPD's Avatar
has anyone tried mounting them to the wiper arms? i kno 2 pontiac i had did it that way.
Old Oct 1, 2006 | 07:27 AM
Flava_24/7's Avatar
Boosted Panda
Is the hood not predrilled?
Old Oct 1, 2006 | 07:54 AM
chillin014's Avatar
yeah i ended up not putting mine on cause i just didnt want to drill more holes and have more crap on the hood. i bought some generic sprayers at autozone with little adjustable tips for aiming and i was thinking of putting them on the area where the windsheild wipers are mounted. But theo nly way i can think to mount them is by glue but the hose nipple is located under the actual squirter so i couldnt lay it flat or get a hose to it if i wanted to mount it that way.
so as of now, no squirters for me either.
Old Oct 1, 2006 | 08:28 AM
10 psi
the one i worked on was but not nearly big enough for the nozzles to fit.. this was on a 98 max, I am not sure if the 95-97's would be different or not..
Old Oct 1, 2006 | 09:20 AM
jjamzman's Avatar
It is actually very easy. I mounted the original squirters on my CF hood. I took the squirters out of the metal hood and trimmed down the bottoms (the part going through the hood) to be as close to round as I could get. The original shape is not round. This resulted in roughly a 5/16" diameter remaining post. On my CF hood there were two kind of mounting boss type protrusions on the bottom of the hood stiffener right where the squirters belonged. I transferred the locations to the top of the hood by drilling about a 1/8" diameter hole through the centers of these protrusions right through the top of the hood (from the bottom). I then used these as pilot holes and redrilled them from the top with a 5/16" diameter drill. I then deburred with a countersink tool. I fit the squirters into the holes and checked for hose clearance. Once everything looked good, I superglued the squirters to the hood. Reattach the hoses and it is done. It took about 15 minutes.
jjam
Old Oct 1, 2006 | 02:04 PM
ya the hoos was predrilled, but only big enough for the hose to fit, not the nozzle... the nozzle itself is square due to the clips
Old Oct 1, 2006 | 02:05 PM
jjam
awesome, thats kinda what i was looking for... the superglue holds up?? has it ever come lose?
Old Oct 1, 2006 | 04:27 PM
jjamzman's Avatar
So far so good. No signs of loosening after 4 months. Worst case, reglue with epoxy. or Marine Goop.
jjam
Old Oct 1, 2006 | 05:36 PM
Flava_24/7's Avatar
Boosted Panda
If the holes are predrilled, then installing the nozzles is easy.Take a dremel, and either open up the area a bit untill the nozzles snap into place,(which is what Ive done on both of my CF hoods) or use the dremel and shave off a bit off the nozzles.
Old Oct 2, 2006 | 05:22 AM
95mtlMAXSE's Avatar
shift_Puff
CF hood in the winter??? Why?? You'll ruin it, no??
Old Oct 2, 2006 | 06:32 AM
enjetek's Avatar
get adremel...make the holes...and run the rubber hoses underneath the hood. also get hood pins youll feel safer when driving.
Old Oct 2, 2006 | 11:19 AM
ok well ive stated at least twice that i already have holes drilled... and for the hoodpins, how did that topic come up, ive had hoodpins since ive had the hood...
i took a grinder to the clip part under the nozzle to make everything round, no issues there, but the hole in my hood needs to be just a lil larger... i dont feel confident doing that myself...
so is there anyone in the CT/MA area that i could stop by and have you dill a larger hole?? thanks.
Old Oct 2, 2006 | 11:30 AM
Flava_24/7's Avatar
Boosted Panda
No need to drill, use a dremel. It will take off a small section at a time. Just test fit it each time you take a little off untill it snaps into place. Your making a bigger deal out of it then it really is. If you can install hood pins, the nozzles shouldnt even be creating an issue.
Old Oct 2, 2006 | 07:29 PM
i didnt install the hoodpins, i had the body shop do it when u put on my stillen kit...
and also i dont own a dremel, thats y im askin if anyone around me has one that i could use or have them do it for me
Old Oct 2, 2006 | 07:48 PM
Flava_24/7's Avatar
Boosted Panda
You should buy one, there not that expensive and you would be surprised how often you will use it. Whatever a shop would charge you to do the install of those nozzles Im sure would be around the same price as a dremel.
Old Oct 2, 2006 | 08:55 PM
sunten1
Talk to BlackMaxima he lives in CT and he is good with the dremel.
I would love to help you, I live in CT aswell, and I do own a Dremel. The problem is I suck at using it.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
Hdnseek
Sep 9, 2015 05:55 AM
