Low fuel light WTF!!!
Old Oct 2, 2006 | 05:09 PM
Groundz's Avatar
I Have had my max for almost three years now, and only once have I ever seen the low fuel light come on. When it came on the needle was so far down past E it was a bit un-nerving. I've never ran out of gas with it, but it would be nice to know if the bulb works just incase I'm on the high-way during a long trip with the next exit being 12 miles away.
First question: If the light is fuctioning properly should it come on when the key is in the run position prior to starting?
Second question: How low does your needle go before the light comes on?
Third question: Is there a way to check if the light is functioning without removing the gauge cluster?
Old Oct 2, 2006 | 05:12 PM
KINGMAX's Avatar
mine blips on and off depending if I am on an incline, or turning, or driving hard. It has never really stayed on. It is not good to let your gas get that low. It is bad for the fuel system because of the sediment that forms at the bottom of the gas tank.
Old Oct 2, 2006 | 05:26 PM
YoKramer's Avatar
+1
Mine will go on a off, It kinda fades in and out for a while, and I can usualy get ~ 30mi outa it before I have to fill up.
Old Oct 2, 2006 | 06:13 PM
98SMG's Avatar
If your needle reaches E and the light does not come on you prob. need to change the bulb.
Old Oct 2, 2006 | 06:32 PM
babymac's Avatar
BOOST 4 LIFE!
When the light comes on you got a good 2 gallons left.
Old Oct 2, 2006 | 06:34 PM
Wassup2114's Avatar
When my needle hits E I have around 4.5 gallons left. I've never even seen the light come on, so I have no idea if mine even works.
Old Oct 2, 2006 | 07:39 PM
BlackMaxdout's Avatar
I've never seen mine come on either. I took the bulb out one day while i had the cluster out, and the bulb looked fine. Weird sized bulb too.
Old Oct 2, 2006 | 08:11 PM
jxkim's Avatar
you could not let your gas get that low and fill it up sooner.
just a thought
Old Oct 2, 2006 | 09:50 PM
sachmo's Avatar
i havent seen my low fuel light turn on for about a year. Is there a guide to changing the bulb somewhere ont his sight?
Old Oct 2, 2006 | 09:56 PM
Ceasars Chariot's Avatar
Old Maxima Legend
i have no idea if mine works either, it comes on sometimes and goes off with no accuracy of where the needle is ? one thing i can say is that even driving on E as many times as i have, i have never ran out of gas in almost 9 years of hard core maxima cruising !!
Old Oct 2, 2006 | 10:08 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
I have never seen mine come on either, I have been below the E before too.. I was just thinking about this earlier today
Old Oct 2, 2006 | 10:25 PM
nguyen925's Avatar
just a thought
what he said.
Old Oct 3, 2006 | 01:08 PM
what do you need a guide for? Take the cluster out, and undo the little bulb holder. Change bulb, replace holder, place cluster back in. Done. Figuring out what bulb that is, is the hard part, and it can't even be that hard.
Old Oct 3, 2006 | 02:08 PM
gassian's Avatar
I haven't seen mine either..had the car for 5 years and the needle reached E before and no lights...
oh well i don't usuallly let mine reach E...
Old Oct 3, 2006 | 02:26 PM
Groundz's Avatar
Originally Posted by gassian
I ha...
I never let mine get that low either, I guess it's just one of thoes nit picky things that drive me nuts. I guess it would help me sleep better knowing everything is working the way I want it to. (I know, I'm fuct up). Anyways thanks for all the replies.
Old Oct 3, 2006 | 02:28 PM
Nissan 6's Avatar
Mine is very random and seems VERY off. The needle would be at 1/8 and it would go on. wtf
Old Oct 3, 2006 | 02:44 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
not if you let it run to empty b4 refilling. not all the way empty just almost. why would you fill it up at 1/4 or half and let that crud build then that ONE time your not by a gas station your screwed and suck all the built up stuff into the injectors the filter will only stop some of it.
Old Oct 3, 2006 | 04:34 PM
markd248's Avatar
during the time the max was my dads, and now that its mine, ive seen the low fuel light come on once. my fuel gauge always goes way above F when its full, and way below E before the light comes on. its wierd, but i never let the needle go below E before i fill it back up.
Old Oct 3, 2006 | 09:08 PM
So wait the needle goes down as far as it goes up? Mine goes above F, so would I have to take it way down to make the light come on?
Old Oct 3, 2006 | 09:17 PM
96blkonblkse's Avatar
mine comes on somewhat randomly. one time the needle was below E and i was getting kinda worried and just and the light came on, on a hill when i was stopped at the lights, maybe 1km away from the gas station, i put in about 63 liters which means it comes on with about 7 remaining?
Old Oct 3, 2006 | 10:00 PM
KINGMAX's Avatar
damn the U.S. and the U.K. for lack of metrics, all of science is in metric....why can we not give in to the rest of the world?
Old Oct 4, 2006 | 04:36 AM
Rydicule's Avatar
Don't you know who I am?
just a thought
The car is at it's lightest when the tank is below 1/4. That's where you get the best gas mileage. Not that it makes enough of a difference for me to personally care, but I've heard people doing a lot crazier things to preserve gas, so...
kjlouis
Nov 24, 2018 06:09 AM
Roymg
Sep 3, 2018 05:10 AM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 6, 2015 11:36 AM
