Cheap Gas makes my 99 Maxima misfire!!
Old Oct 3, 2006 | 06:39 AM
asianbandit's Avatar
I read tons of bulletins on this forum debating about what type of gas to put in the Maxima. I always figured it was not that big of a deal. Now I have learned that the cheap 87 octane gas makes my car misfire. No more cheap crap for my Max, only 93 octane from now on. Don’t wait for your car to misfire, only put 93 in it.
Old Oct 3, 2006 | 06:40 AM
MaximaSE96's Avatar
Maxima Owner
go diesel or go home....and it prolly did nothing to ur car.....87 will not cause a misfure
Old Oct 3, 2006 | 07:28 AM
99grnmaxgxe's Avatar
Are you sure it's not your coilpacks? You do have a 99.
Old Oct 3, 2006 | 07:36 AM
maxima92se's Avatar
yeha the typical 87 normaly would just cause lot lots of low end power loss because of a knock sensor because it retards the ignition or some shyte. But not a misfire.
Old Oct 3, 2006 | 07:41 AM
ALSOUSA99MAXIMA's Avatar
ANOTHER GAS THREAD!!!!!!!!!! Why not just post in one of the other million gas threads???
Old Oct 3, 2006 | 07:42 AM
this is for you asianbandit
http://www.albinoblacksheep.com/flash/posting.php
Old Oct 3, 2006 | 08:08 AM
Nissan 6's Avatar
You should have listened on the other hand, gas is overrated.
Old Oct 3, 2006 | 08:33 AM
FAKATA's Avatar
I dunno , I always put 93 in , but recently I was forced to fill up with 87 ( Gas station had no other gas , and I had none whatsoever ) , I got to tell you , big difference , never gona do it again .
Old Oct 3, 2006 | 09:56 AM
x X CLoud X x's Avatar
i run 87mobil all the time, i def. get no misfire, its an n/a how much octane does is it gonna require, its not like im running a turbo w/ 36psi, retards a little timing so what
Old Oct 3, 2006 | 10:03 AM
MaximaSE96's Avatar
Maxima Owner
thats al it will do is retard timing a little...it jsut in peoples minds and butt dynos that 87 is bad....i still used 93...but i wouldnt hesitate to put 87 if i needed
Old Oct 3, 2006 | 01:33 PM
Apparition's Avatar
Ichiban King
Originally Posted by ALSOUSA99MAXIMA
man that video should be a sticky, just change all the "steam" to maxima.org and you're set..
Old Oct 3, 2006 | 02:50 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
my heads gonna pop if i see another gas thread ive said this a million times your computer IS PROGRAMMED FOR 87 OCTANE FUEL. if some gas fairy is making the engine seem to misfire when its put in its not the gas. check your coil packs, knock sensor, and fuel injectors. make sure all your computer codes are clear. please delete this thread.
the only way to utilize the higher octane is to get an upgraded ecu programmed for 91 octane from jwt or TS. now i must take pause to vent my frustration at a totally anonomous person not expecting it because i feel like it......just kidding....
please search
Old Oct 3, 2006 | 06:03 PM
Thahman's Avatar
oh gees. if it's so irritating then let it be. people will <i>always</i> ask repeated questions. It's life. It's people.
Balkins
Aug 12, 2015 06:39 AM
MikesChevelle
Aug 6, 2015 11:36 AM
Jcof88
Aug 3, 2015 10:43 PM
yat70458
Aug 3, 2015 01:16 PM
