spark plug gapping
Old Oct 3, 2006 | 10:23 AM
Maximeltman's Avatar
spark plug gapping
Do the NGK coppers for the 4th gens come pre-gapped to spec or do we need to gap them before installing? They say like 1.1mm or .40, whatever you like. I checked them with a gap tool and they seemed fairly on-point. But do they need to be gapped? I just installed them after I threw a 0603 for a bad 6th cylinder and just replaced them all but the car still sputters a bit, but it's better than before. Any help much appreciated.
-Also, they seem a bit hard to gap without breaking or damaging them!
Old Oct 3, 2006 | 10:32 AM
mtrai760's Avatar
'Trynna' is not a word
All spark plugs require gapping before installation.
Old Oct 3, 2006 | 10:40 AM
MaximaSE96's Avatar
Maxima Owner
actually NGK double plats...the kind recommended are pregapped with specification for our cars.......double check teh coppers though
Old Oct 3, 2006 | 10:58 AM
I get a fat knock now this blows. how does spark plug gap effect the engine? Anyone gapped sparkplugs before? Do I need a special tool or what?
Old Oct 3, 2006 | 11:02 AM
MaximaSpd85's Avatar
u need a gapper...like .99 cents at an auto store. gap should be .044.
V-Powers do not come pre-gapped. other brands-i do not know
Old Oct 3, 2006 | 11:36 AM
I just replaced all 6 plugs. still the same code: cylinder 6 misfire...I checked the resistence on all coilpacks and the all checked out fine...what could be causing this misfire? I got a gapper though, but the plugs factory gap was just a hair off from spec btw. If all the plugs were not gapped right, would I still only get a cylinder 6 misfire code?
Old Oct 3, 2006 | 11:42 AM
glenmoormax's Avatar
10 psi
if the part number has a -11 after its already pregapped to .44 which is factory spec. Now to help reduce that knock which I think is too late already, try to reduce the gap to maybe .38-.36 or so and see what happens.
Old Oct 3, 2006 | 12:03 PM
matrix11229's Avatar
I had the same problem.
You have to gap them to 0.044 inch.
Don't put too much anti-seize on the threads and don't apply too much torque on the plugs , they have to be just snug.
Old Oct 3, 2006 | 12:06 PM
MaximaSE96's Avatar
Maxima Owner
MY PFR5G-11 WERE GAPPED PEFRECT....certain Bosch Platinums are pre gapped as well but Bosch = Bad....but the coppers need to be gapped
Old Oct 3, 2006 | 12:23 PM
mtrai760's Avatar
Copper, Platinum, Iridium, doesn't matter, Ive always found at least 1 off measurement. Don't use those cheap generic plug gappers, get a set of feeler gauges and do it right.
Old Oct 3, 2006 | 12:25 PM
so you think that if they are all not gapped correctly my ecu will throw only a misfire code for cyl 6
Old Oct 3, 2006 | 12:26 PM
d00df00d's Avatar
Old enuf to pick his own gears
They will come pre-gapped, but you always want to check the gap just to be sure that all that knocking around during shipping didn't change anything.
Old Oct 3, 2006 | 12:30 PM
All spark plugs come pregapped from the factory, but not pregapped specifically for your car. Different cars need different gaps. Nissan requires a 0.044 gap. Different gap may work fine but it's not the optimal setting for your car. Get the gapping tool and set the gap.
I used the Strauss .99c one and it worked perfect.
Old Oct 3, 2006 | 03:50 PM
problem solved i swapped the packs on 4 and 6 noe 4 is giving problems. i get to treat myself to a new coilpack yay.
Old Oct 23, 2006 | 03:36 PM
jlander82's Avatar
Has anyone tried the NGK v power plugs? Good/bad?
Old Oct 23, 2006 | 04:35 PM
Yes , that's the copper plugs and they are perfect and cost only $12 per set of six.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
