Thoes with SS brake lines
I just got my new pads and the goodrich SS lines, Is there anything to look out for when replacing the lines. IE any thing that might brake when I try to remove do to rust? Any advice would be great, thanks to all that respond.
Use flare nut wrenches on all of the brake line fittings that you cant get a socket on. Get some decent ones too. The cheap ones dont fit as snuggly and might bend a little under pressure. You might need some pb blaster to help loosen any rusted parts.
Originally Posted by Dubbya
Use flare nut wrenches on all..... You might need some pb blaster to help loosen any rusted parts.
Brake Bleeding
Originally Posted by Groundz
Alright an excuse to buy mor tools, thats what I wanted to hear. PB Blaster is my best friend I use it on anything with any sign of corrosion. Thanks for the fast replies. Oh, and break bleeding is done from the closest wheel first or the farthest first?
Originally Posted by Curt
Whoa, back up the bus, guys. Per the FSM it's RR, LF, LR and then RF. Don't know why it's changed from the traditional sequence of starting from the furthest to the closest, but I suspect it has to do with cars now having 2 separate brake circuits, each working on diagonally opposite corners of the car.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
