Weight distribution of a Maxima and how to imporve it?
Old Jun 27, 2001 | 11:57 PM
SWEETSOUND2001's Avatar
What is the weight distibution of a 97 gxe to be exact? How can it be improved besides relocating the battery? i will be adding about a 100 pounds of stereo qeuipment pretty soon.
Old Jun 28, 2001 | 01:09 AM
BrianV's Avatar
Other than the battery there isn't much you can do. If you take out power steering, A/C, ABS, etc. you can reduce the front weight which helps to balance the weight ratio.
BrianV's Avatar
My guess would be 63/37 (sorry forgot it in the last post)
Old Jun 28, 2001 | 03:08 AM
party_boy's Avatar
if you're doing a custom install...
try to put the weight between the axles of the car. With a custom installation you can put some of the weight between the cabin and engine. i.e. subs crossovers..etc...
That's all you can pretty much do unless you want to put lead weights in the engine bay....
Old Jun 28, 2001 | 03:17 AM
OgreDave's Avatar
carbon fiber hood?
Old Jun 28, 2001 | 05:32 AM
fast97maxse's Avatar
swap the VQ for a 4banger from a sentra!
Old Jun 28, 2001 | 05:30 PM
party_boy's Avatar
oh yes
forgot...just tie a few hundred helium baloons to the rear bumper and it will lift up. =P Hey who'd notice?
Old Jun 28, 2001 | 10:26 PM
Weasel's Avatar
BrianV gets a cookie... the weight distribution of an Auto GXE is 63/37. Interestingly, the distribution of a 5-spd SE is 62/38.
Old Jun 28, 2001 | 10:50 PM
supertool
I believe Home Depot sells weight distribution kit for the Maxima.
AKA cinder blocks Put some in the trunk, and hit 2 birds with 1 shot. Improve weight distribution, and save on lowering springs
Old Jun 28, 2001 | 11:33 PM
Re: I believe Home Depot sells weight distribution kit for the Maxima.
Actually it kills 4 birds. Thw two you mentioned and these two: your suspension and gas mileage
Old Jun 29, 2001 | 01:27 AM
OgreDave's Avatar
The autotranny probably makes up that 1% in weight dist.. but it makes up more than that in parasitic loss..
Old Jun 29, 2001 | 07:16 AM
mzmtg's Avatar
Minister of Silly Walks
Installing your heavy equipment in the trunk will help your weight distribution. Your overall weight will go up(bad). But, your distribution percentages will improve(um...good).
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
julian888
Aug 6, 2015 04:39 AM
