Warning to all guys with blown hood struts
Old 10-08-2006, 03:38 PM
  #41
1996blackmax's Avatar
Pop open the hood, then take a vicegrip and clamp it right under the hood strut where the piston comes out. I did this for a while as well....
1996blackmax is offline
Old 10-08-2006, 07:33 PM
  #42
miserov's Avatar
Location: You can't spell 'Wisconsin is insanely boring" without "Wisconsin."
A golf course water-hazard marker pole works great.
miserov is offline
Old 10-08-2006, 09:50 PM
  #43
Fast1one's Avatar
I use a banboo stick I had laying around lol...
Fast1one is offline
Old 10-08-2006, 09:53 PM
  #44
VQ35 FTW
mastercater7's Avatar
ya me and my buddy were changing his intake on his 93 today when they went out. he had his head over the engine when it fell. it was hilarious.
mastercater7 is offline
Old 10-13-2006, 12:39 PM
  #45
toddemullins's Avatar
I would recommend the generic ones from Advanced or Auto Zone. Mine fail about every two years or so, but they have a lifetime replacement and I just swap them out. I think they come to around $15 each. One of you machine shop guys should come up with a design for a solid one that snaps onto the factory posts. I bet some of you fancy guys would buy them for when you show off all the shiny stuff under your hoods.
toddemullins is offline
Old 10-13-2006, 03:02 PM
  #46
super6's Avatar
Originally Posted by Nissan 6
I'm curious as to how your going to pleasure yourself if it hurts.
Switch hitting ftw.
some times good to have an auto and a girl
super6 is offline
Old 10-14-2006, 04:05 AM
  #47
nismology's Avatar
This man speaks the truth.
nismology is offline
Old 10-14-2006, 08:50 AM
  #48
Ichiban King
Apparition's Avatar
fawkin vice grips.. those basterds slipped on me also, one time. my head hurt for a few days subsequently..
Apparition is offline
Old 10-14-2006, 09:34 AM
  #49
96i30azn's Avatar
Originally Posted by happy4444
can sumone explain the whole vicegrip rigging
you put visegrips on the rod just below the cylinder so that it cant go down
I bought my aftermarkets struts for 30$ shipped a pair.
http://www.rockauto.com/catalog/x,ca...t,partGroup,12
96i30azn is offline
Old 10-14-2006, 12:57 PM
  #50
Licensed to Spell
ptatohed's Avatar
:o)
Originally Posted by black97
I poped up the hood today to check some stuff and for some reason i put my hand on the fender but i didn't mention that the hood was going down slowly......all i remember that 3 of my fingers stuck between fender and fully locked hood and here's the result after about 3 hours
Lesson learned(too late) beware guys fingers worh more than 100$
oh yeah sometimes it's good to have an auto trans.
I have never been so confused.
You just did mention that the hood was going down slowly. ?
Your fingers were stuck for 3 hours? How did you get them out?
"fingers worh more than 100$" Huh??????????
The damage to your fingers would have been worse had you owned a stick shift?????
ptatohed is offline
Old 10-14-2006, 01:28 PM
  #51
NAS
NAS's Avatar
jesus if anybody has blown hood struts stop being a cheap *** and just replace them, anyone that has to work on the car will thank you for not being cheap, I dont know how many freaken cars I had to use vice grips on when I was in the windsheild business, and they dont hold 100% of the time.........................................=hurt shoulders and heads=mad techs at the owner!
NAS is offline
Old 10-14-2006, 03:06 PM
  #52
Jatan's Avatar
My StrongArm hood supports (lifetime warranty) are about to die - now I have to find my receipt for it
Jatan is offline
Old 10-14-2006, 09:44 PM
  #53
Porgie's Avatar
ouch man... that sux big time... u should slam the rest so tehy can match
Porgie is offline
Old 10-14-2006, 11:12 PM
  #54
aaa99max's Avatar
hood struts are cheap from autozone, problem solved.
the blood clotted under your nails, will make the nail above it rot out. eventually they will fall off and a new one will grow in. make sure that you put a band-aid over the open flesh. easy to get infected there.
aaa99max is offline
Old 10-15-2006, 12:08 PM
  #55
MDeezy's Avatar
Originally Posted by Ceasars Chariot
im still using vice grips as well, sorry about your fingers, i thought you were meaning the hood slamped on your hands and you were stuck for 3 hours? that would have been totally lame !
I thought he meant that too! . . . that would suck, hood fully lock, you hands are trapped, nobody around. . .
If you had a CF hood, it would have shut and locked on your fingers, not enought weight for it to pick up speed fast enough.
MDeezy is offline
Old 10-15-2006, 05:08 PM
  #56
Donating i30 Owner
HomerMAC's Avatar
well if vice grips dont work.. i would expect the struts to not work under certain conditions... over any work that takes a long period of time a SMART tech. woud put a pipe or something to support the hood.
HomerMAC is offline
Old 10-15-2006, 09:33 PM
  #57
Luisjo's Avatar
ouch. mine are blown too. i just use a piece of wood at the back of the hood
Luisjo is offline
Old 10-16-2006, 10:12 AM
  #58
julioenr's Avatar
get some screws in that...
I had blown struts for looong lonng time, and what I did is took the struts out drilled out a hole in them and put a screw in the hole everytime I pop the HOod.... works better than a set of struts breaking every once ina while....yeahh cheap stuff.
julioenr is offline
Old 10-16-2006, 10:29 AM
  #59
X-Vert's Avatar
you're the only one that seems to be confused...
anyway... it looks like ur nails are going to fall out lol, sorry to hear about that.
X-Vert is offline
Old 10-16-2006, 10:41 AM
  #60
shadyonedeath's Avatar
Smartest Idea Yet.
Ill try that.
Kind of reminds me when your lifting weights, and you slide a pin to the desired weight amount.
shadyonedeath is offline
Old 10-16-2006, 09:39 PM
  #61
So...how do you remove the struts?
Im gona try that drilling a hole and using a bolt method.
Old 10-16-2006, 09:57 PM
  #62
MDeezy's Avatar
12mm wrench. use the open end.
MDeezy is offline
Old 10-17-2006, 03:56 AM
  #63
All that trouble to save $30 when most of struts you buy through Autozone, Pepboys, Advanced Auto, etc. all come with lifetime replacement warranty? Not sure about the logic with that.
Old 10-18-2006, 09:38 PM
  #64
Licensed to Spell
ptatohed's Avatar
:o)
Then explain it to me.
Why did he say he forgot to mention the hood was going down slowly when he did mention it was going down slowly?
What does this mean in English: "fingers worh more than 100$"
What does having an automatic transmission have to do with slamming fingers in hoods?
ptatohed is offline
vingodine
45
05-21-2016 12:46 PM
FlaMark
25
08-28-2015 10:15 AM
raffivegas
08-23-2015 09:54 PM
maxipower
08-21-2015 11:10 AM
doobadoo
08-15-2015 06:43 PM
Quick Reply: Warning to all guys with blown hood struts
