Mass Air Flow Sensor
Hey
So my check engine light came on yesterday and I performed the self diagnostic test with the ECU and the code that I got back was 01 02 Mass Air Flow Sensor. The problem that I experience every so often is that every so often when I am speeding up, my car chokes a bit and occationally even stalls out.
How would you go about fixing the MAF? Is it possible to clean the MAF or is it an item that you just need to buy and new one. I looked at the prices of them and they are pretty pricey. Would it be a good junk yard item?
If anyone knows anything about it, any information would be appreciated.
I got a 4th gen unit for 45 shipped... www.car-part.com
Originally Posted by ofgortens
Hey
MAF for Maximas arent supposed to be cleaned with ANYTHING. I was told this by a Nissan tech. after asking about cleaning mine. He subsequently gave me a working MAF. The 3rd gen MAF is not interchangeable with yours (I have one).Your best bet is getting it used or new if it's affordable.
Be sure to reconnect the wire on the MAF tube( I dont know what it's called)It's like a sensor before starting the car. I forgot to reconnect mine and it triggered the CEL which was on for a month until I finally had it resetted over the weekend. Disconnecting the battery overnight didnt help with the CEL either.
Good Luck.
Good Luck.
Good Luck.
Go to a junk yard, or purchase one from a meber on here. it is easy to install and it should fix your sputtering and stall outs
and to reset the ecu all you gotta do it go to a autostore and use their obd. or 95 - 98 turn the screw on the ecu
Originally Posted by ManualMaxima
of course they aregoing to tell you that......but if it is alreay messed up, why not try cleaning it with electrical parts cleaner? ifit fixes it awsome, if not, well you are in the same boat you were already in, no real loss.
RWCreative
Sep 21, 2015 11:01 AM
lux97Max
Sep 4, 2015 05:42 PM
