maxima not starting
Old Oct 11, 2006 | 08:51 PM
Tino98max's Avatar
maxima not starting
As Im leaving from 12 hours of work today, i go start the car, the car doesnt start at all. Makes a few groaning noises, please help what could this be?
many thanks
tino
Old Oct 11, 2006 | 08:54 PM
NmexMAX's Avatar
dot dot dot ...
'Few groaning' noises does that mean?
Do you have lights/radio? Is it cranking?
dead starter
dead battery
bad GND points
Bad pos. batt points
# of different fuses
Fusible link
CPS
ECTS
Too vague..need more information
Old Oct 11, 2006 | 08:59 PM
Tino98max's Avatar
dead starter
dead battery
bad GND points
Fusible link
CPS
ECTS
sorry that was vague, yeah the battery is fine, cuz all the lights go on, when u turn the key, but then when i turn to ignite the car it is trying to turn over, and just groans a couple of times and dies
Old Oct 11, 2006 | 09:03 PM
NmexMAX's Avatar
dot dot dot ...
Might very well be a battery on its way out. Possibly a bad GND on the battery terminal.
Check those...
Old Oct 11, 2006 | 09:17 PM
Tino98max's Avatar
whas a GND?
Old Oct 11, 2006 | 09:42 PM
GeorgeRamosjr's Avatar
GND = ground... the wire bolted to the body of the car to complete the circuit
Old Oct 11, 2006 | 09:54 PM
gmax96's Avatar
time for an optima battery!
Old Oct 12, 2006 | 12:53 AM
Max96-97's Avatar
It might be the battery as others mentioned. You may just need a battery service or check first. Does it throw any code(s)? It could also be the engine coolant temp sensor (ECTS).
Old Oct 12, 2006 | 09:38 AM
addictjokah's Avatar
Sounds like the battery. Same thing happened to me. It'll groan a couple of times and then nothing. The lights do turn on but the battery's about to die.
Old Oct 12, 2006 | 10:50 AM
Tino98max's Avatar
yeah exactly, and i noticed the positive terminal was all corroded
Old Oct 14, 2006 | 09:21 PM
Porgie's Avatar
Maxima won't start ... also turns off when it is idling
Hey all just got a 96 maxima .. high miles 215,000 miles any how when i am driving if i am at a light... or let the car idel.. the rpm will go all the way down adn the car will shut off... If i rev up the car with the brake on i can keep gogin.. anyone know wat the problem could be?? thanks
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
halfpol
Aug 5, 2015 08:24 PM
Jcof88
Aug 3, 2015 10:43 PM
