Will this tire size fit?
Old Oct 12, 2006 | 06:54 PM
GarciaMaxima's Avatar
I have the OEM 97 SE rims the OEM tire size is 215/55-16 which is the tire size I currently have. My friend is trying to sell me 205/55-16 brand new tires will they fit? What does the 205 number measure?
Old Oct 12, 2006 | 07:26 PM
JSMax's Avatar
Sold
oi, 205 measures the section width of the tire in millimeters. Basically it's the tread width of the inside of the tire.
55 is a measurement of the % of the first number and relates to the sidewall height.
16 is the rim size.
Yes, 205-55-16 will fit your stock rims, but the tire will have a smaller diameter and therefore it will throw off your speed-o-meter. how much? More importantly will you notice it? Not that much <1% @100 km/h. Will you notice it... probably not. You might even gain some quicker acceleration.
hope that helps.
Old Oct 12, 2006 | 07:32 PM
Sounbwoy's Avatar
Go herehttp://1010tire.com/TireSizeCalculator.asp
and you can see how much it may throw you off by...
Old Oct 13, 2006 | 04:41 AM
JSMax's Avatar
Sold
good find. I forgot about the online calculator.
Old Oct 13, 2006 | 11:00 AM
Great. Thanks for the good info & responses.
Old Oct 13, 2006 | 11:01 AM
so this tire is essentially smaller. Will it leave a bigger gap between the tire and fenders?
Old Oct 13, 2006 | 12:05 PM
Sounbwoy's Avatar
Remember the 205 is the WIDTH in mm. It's the same aspect ratio/sidewall height (55) as your existing tire
Old Oct 13, 2006 | 02:13 PM
Thanks for clarifying that.
Old Oct 13, 2006 | 02:17 PM
one more thing? is it recommended to use that different size? or should I say is it bad? besides the speed-o-meter being off by a alittle bit.
Old Oct 13, 2006 | 02:38 PM
Ceasars Chariot's Avatar
Old Maxima Legend
205mm = 8.07 inch
215mm = 8.46 inch
225mm = 8.85 inch
Old Oct 13, 2006 | 06:43 PM
JSMax's Avatar
Sold
side wall is a percent of the casing
205 @55%=112.75
215 @555= 118.25
225 @55%= 123.75
height in mm of the side wall.
yes, the same aspect ratio will have a shorter sidewall depending on the casing measurement of the tire.
alahjahwan09
18
Sep 21, 2015 09:12 PM
minsbang
Sep 11, 2015 08:48 PM
carid
Sep 9, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
