Aluminum vs. Stainless Steel
Old Oct 13, 2006 | 03:55 PM
MaximaSpd85's Avatar
Yeh, i know a b-pipe doesnt do too much for our car, but are their any major differences flow-wise between aluminum and steel when it comes to exhaust components, regarding b-pipes in particular? Is it just that the steel is better looking and better against rust? I havent ever heard any complaint about aluminum y-pipes not making as much power as SS y-pipes, but then again ive never looked into it until now... edit: okay so i just found that i was wrong about the rust part, its actually the other way around..aluminum does not rust, ss may rust....
Old Oct 13, 2006 | 04:01 PM
streetzlegend's Avatar
just get w/e is cheaper. all same caca, as long as its mandrel bent
Old Oct 13, 2006 | 05:00 PM
adithius's Avatar
Performance wise it's the same. The difference is the $$, looks, and wont rust as easily.
Old Oct 13, 2006 | 05:15 PM
MDeezy's Avatar
spend $10 and get some high temp paint and paint your alimunized exhaust and keep it protected. NC does see some snow now and then ( from what I remember )
Old Oct 13, 2006 | 06:14 PM
95mtlMAXSE's Avatar
shift_Puff
i got stainless cause it doesn't rust and i live in canada...if u get alluminum it's all good too, it'll just rust differently(not orange)
Old Oct 14, 2006 | 10:33 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
No, Aluminized DOES rust, SS will not rust.
Old Oct 14, 2006 | 11:18 AM
MDeezy's Avatar
I just painted my aluminzed exhaust. Should defiantely slow down the rusting process.
a good $10 investment.
Old Oct 14, 2006 | 12:48 PM
ptatohed's Avatar
Licensed to Spell
I wonder why nobody talked about weight. I prefer aluminum because it is much lighter than steel.
Old Oct 14, 2006 | 01:29 PM
dgeesaman's Avatar
Maintenance Monster
SS can rust, depending on the type. But it's almost always just cosmetic rust.
Dave
Old Oct 14, 2006 | 03:14 PM
adithius's Avatar
If you are going to paint it, make sure it's high temperature paint.
Old Oct 14, 2006 | 04:17 PM
eng92's Avatar
There is no weight savings with aluminized steel.
It is just cold rolled sheet steel with a very thin (~0.001") coating of aluminum alloy applied to both sides.
Old Oct 14, 2006 | 04:23 PM
MDeezy's Avatar
2 cans of Autozone high temp paint, can do two good coats, on a y+b+muffler.
Old Oct 14, 2006 | 04:29 PM
eng92's Avatar
Depending on your driving habits, painting can be a just a waste of time and money. Frequent short trips don't heat up the entire exhaust enough to vaporize the water that is produced by the combustion process. The pipes rust from the inside out due to the standing water present.
I used to live only about 4 miles from work and I would have to replace the cheap aluminized steel b-pipe in my supra due to rust-through every year. I moved about 25 miles further away and the same cheap pipe lasted about four years before I junked the car.
Old Oct 14, 2006 | 04:35 PM
MDeezy's Avatar
Thats right they can rust from the inward out. For those who live in climates that have bad weather conditions. For those who plan on keeping their cars for a while, it would be smarter to spend a bit more and get SS exhaust.
If I still lived in ontario, I would get SS pipes all around.
Old Oct 14, 2006 | 09:45 PM
Porgie's Avatar
alimumun is lighter but more prone to rust
Stainless tell is heavier.. not really storng nand will rust.. but is cheaper
Old Oct 14, 2006 | 10:26 PM
Cdg2125's Avatar
So painting is the only way to really slow rusting on the alumized?
Old Oct 14, 2006 | 10:31 PM
96blkonblkse's Avatar
stainless steel can rust. but it will rust very, very slowly compared to aluminum. There is no performance difference aslong as there both mandrel bent. Most of the time the only part that rusts are the flanges because sometimes they arent stainless steel.
Old Oct 14, 2006 | 11:04 PM
aaa99max's Avatar
if you can't do anything to save aluminum. you're $10 can go to a decent exhaust.
Old Oct 15, 2006 | 12:42 AM
Vlasic's Avatar
Absolutely EVERYTHING you just said was wrong. Where did you get your facts? You obviously dont know what your talking about and the exact opposite of what you said had already been mentioned more than once in this thread.
Old Oct 15, 2006 | 07:04 AM
eng92's Avatar
It is the thread title that is confusing a lot of people.
It should have read "Aluminized Steel vs Stainless Steel"
You will not find an aluminum or aluminum alloy exhaust for a maxima.
The strengths of all the reasonably priced aluminum alloys decrease rapidly with increasing temperature so they are not suitable materials for exhausts.
Subjected to the same environmental conditions, a stainless steel exhaust will always outlast an aluminized steel one. It is the same reason that a stainless steel heat exchanger in a furnace will always carry a longer warranty than an aluminized steel one.
Apr 16, 2020 05:15 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
lux97Max
Sep 28, 2015 11:18 PM
Spartan1310
Sep 28, 2015 08:03 AM
lrb6805
Sep 18, 2015 07:07 PM
