Tires - How wide can they go on a Max?
Old Oct 16, 2000 | 10:46 PM
philpoe's Avatar
4 Maximas and counting
I'm looking at some rims for my 96 SE, and I have a line on some 16x8s. I'm currently running 225/55/16 but the 8" will support up to 245, right?
Can a 4th gen tuck those all the way in?
225 and 245 aren't that much difference in price in the tires I want (< $110 ea), and I have plenty of choices, while 235 in 16" is rare (1 performane choice at tirerack) and expensive (~$200), which is why I'm looking at going 225->245
thanks
Phil
Old Oct 16, 2000 | 11:47 PM
Southpaw17
what ever u do dont go wider than 8, and u can go with 245 but 235 is better it wont throw the speedometer off that much.
DEBO
Old Oct 17, 2000 | 03:18 PM
Micah95GLE's Avatar
I think that if you use 245s on 16s, you'll need 245/40/16 to keep the outside diameter close to stock.
Old Oct 17, 2000 | 03:23 PM
Jeff92se's Avatar
I'm needing a caw
Please go here-->
http://www.miata.net/garage/tirecalc.html
You can figure out what size you need. Just a hint, 245 is pretty wide but probably possible. You will need to pay more attention to the offsets to make sure it doesn't rub on the struts. 235 would be a good choice. Just play around w/ the aspect ratios to get the proper wheel dia. It will probably end up being 55 or 50
thanks
Phil
Old Oct 17, 2000 | 03:59 PM
Micah95GLE's Avatar
Darn. The AR would be either 45 or 50.
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
