rear brakes
Old Oct 15, 2006 | 09:32 PM
d1max2nv's Avatar
rear brakes
i hate changing the back brakes on my max. its such a pain in the ***! why didnt nissan just make them like the front ones where you just push them in, instead of that spinnging **** and having to get a tool just to change your rear pads. this sh*t sucks. tonight i spend almost an hour changing my rear pad, becuase it was 10pm, and all the auto parts store were closed so i couldnt get the tool to change them.
Old Oct 16, 2006 | 04:09 AM
Groundz's Avatar
Use a pair of vice grips and clamp them on one of the 4 tabs of the caliper piston, turn the piston as far as you can, repeat till the caliper can be slid over the pads and rotor.
Old Oct 16, 2006 | 05:31 AM
ARN1CK's Avatar
they dont just slide back to the enitial spot like most cars...i thought u were supposed to just use a c clamp with the old pad over the piston
Old Oct 16, 2006 | 11:33 AM
Groundz's Avatar
The front calipers will push back in, Use the old pad over the piston and position the C-clamp on the center of the caliper and press the piston in. The rears however need to be turned in, your c-clamp will break before you push the piston in on the rear. On the rear pistons you will see 4 tabs, clamp a set of vice grips on one of the tabs and turn the piston in. Make sure that your rubber piston boot does not turn with the piston, if it does it can be gently tugged by hand to strighten it out.
Old Oct 16, 2006 | 01:25 PM
Dubbya's Avatar
VK56 Inside
I think they are pretty easy.
Old Oct 16, 2006 | 01:30 PM
Groundz's Avatar
They are a breeze, as long as you know the rears turn in and not push in.
Old Oct 16, 2006 | 01:37 PM
sam29281's Avatar
it's a pain in the butt to turn in with a needle nose. I bought a tool to turn it in for the next job.
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
