Does anyone know where i can find these two parts?
Old Oct 17, 2006 | 07:17 AM
loverholic's Avatar
iAMIXAM!
my check engine light came on and i got 4 codes... two of em i kmow where the problem is but the other two i need some help with.... here are the codes;
1: 05 04 = Automatic Transmission Control Unit Signal to ECU
2: 01 04 = Vehicle Speed Sensor
3: 13 02 = MAP/BARO SW Solenoid/Valve
4: 03 04 = Knock Sensor
# 3, i already went to the stickys and found out what i need to check and the knock sensor is self explanitory... but the first two i have no clue where to find them.... i thought the 'Automatic Transmission Control Unit Signal to ECU' was that lil black thing bolted right in the middle of the tranny and engine (where they meet) bu that lil black thing just have a magnetic tip that monitors the flywheel i guess.....
what i really want to know is where can i find the 'Automatic Transmission Control Unit Signal to ECU' and the 'VSS'...if anyone has pics that would be a great help...
Old Oct 17, 2006 | 02:57 PM
RA030726's Avatar
I'm nutty for Nissans
the VSS is in the tranny, if you look down from the throttle body and brake booster area its rigth there.
Old Oct 17, 2006 | 07:42 PM
pmohr's Avatar
No more Maximas...
That little black thing is crank ref sensor. Pull your trans codes with the OD light (search), see what it says, probably concerning VSS.
Old Oct 18, 2006 | 01:27 AM
loverholic's Avatar
iAMIXAM!
my OD light was blinking the other day when i started my car.... but i turned the OD off and then turn it back on and it stopped.. but i just looked over that.. i never really took it seriously... whats the association?
Old Oct 18, 2006 | 02:10 AM
loverholic's Avatar
iAMIXAM!
can someone find the write up on how to pull your tranny code for me please.. i cant search and i looked all over.....please..thx
Old Oct 18, 2006 | 11:32 AM
loverholic's Avatar
iAMIXAM!
hey guys, can low tranny fluid cause the first and the second code.... i checked mine today and it was low... it was at the very tip of the stick.... it was barely touching the stick......
last week i was doing a random check under my car and realized that the 10mm bolts that hold the bottom pan of the tranny was a lil loose, i tighen them almost a full spin... fluid was leaking but not drippin down....
i went a head and refilled the tranny, so now all i have to do is wait and see if the CEL comes back...
homeyclaus
Sep 3, 2015 06:15 PM
max_speed97
Aug 26, 2015 07:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
