Fog Light Question
Fog Light Question
This is something I just got around to trying to fix. My passenger side fog light is cracked on the outside and the light wont turn on. I tried replacing the bulb but that didnt work either. What should I replace to get the light back in working order?
Well has there been water in there? If the light is cracked then you probably got water inside and shorted the bulb at least. Could have shorted the wires as well. It's only one that doesnt light up? If so then you might have shorted that harness.
^ You could have easily shorted the fogs but if both of them don't come on then, check the fuses for the fogs and also the relays. You can swap the relay with another one (they are all the same and just to check if it's the relay).
Thats why I asked about just one lighting up. If only one lights up then just part is shorted. If they both dont light up then the fuse is probably blown and maybe both shorted out. Details are a must here.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
98nismomax
Aug 13, 2015 12:44 PM
