Cattman YG4 pipe ordered
Well I finally did it. I ordered the Cattman Y Pipe for my 97 SE. It won't ship until some time next week though. The next fun will be finding a place to install it because of the pre-cat issue.
Question? How many sensors are located on this piece of pipe that I will need to reconnect?
Next up will be the CAIG4-A Cold air intake piece. This is the intake that locates the air element in the fenderwell. Does anyone have any comparison for me on this one versus the plain POP that keeps the cone element in the engine compartment?
Later from Houston...
There are two sensors in the Y-pipe. As for the install, almost any muffler shop will do the install.
Just make sure that you don't drop the O2 sensors, cause they are really expensive to replace.
You should reset the ECU so that it'll remap for the Y-pipe.
reset ECU
disconnect the negative battery terminal for a couple hours soon after you get the pipe installed. I'll be installing mine myself, so I'll disconnect the battery, install the pipe, and reconnect (assuming it takes me at least a couple hours to put on.
Justin
Justin
OK thats total BS, that any muffler shop will install it. Maybe its because I live in CA, but i've been to like 5 places and nobody will touch my stillen Y pipe because they say they can get in big trouble for removing the pre-cats. This monday me and my friends are gonna have to attempt to do it ourselves.
I live outside of philly and the first place I went to they agreed to do it for $65. I tried doing it myself, but those bolts were just too rusted on, so I let them do it.
Try to see if there is a local speed shop in your area, they are usually more likely to help you out.
Good luck.
Good luck.
06-06-2017 02:01 PM
bigfrank
10-01-2015 12:51 PM
