starting problems???
Old Oct 25, 2006 | 05:22 PM
asperos28's Avatar
the other day i went to start my car and it cranked but wont turnover. It smelled like fuel so it definately has fuel, so then i bought new coils and it still does the same thing? could it be plugs? or watelse can it be?
Old Oct 25, 2006 | 07:56 PM
mikem29ss's Avatar
They sometimes have a problem with the front crank sensor wiring getting saturated with oil. Test the wires, disconnect the 6 wire (I think) connector on the right side above the timing chain cover and check continuity of the wires to the crank sensor. Also check the sensor closely. I would also pull the codes and see if any are tripped, I believe the crank sensor would trip one. They are also prone to ignition switch failures. If the crank sensor checks out, check for a signal at the coils to make sure they are firing. Also, try holding the throttle to the floor when you crank it. This puts the ECM in a flood state which fires the injector every other time, to help clear out the flooded fuel. HTH
Old Oct 25, 2006 | 08:29 PM
asperos28's Avatar
well i got it started once and after its running, it runs fine. its just when i go to start it im screwed again? it sounds like the timing is off or something. it randomly started doing this
Old Oct 25, 2006 | 09:26 PM
Digitized's Avatar
when you crank, do you hear the starter turning?
if not, then replace starter..
Old Oct 25, 2006 | 11:23 PM
ptatohed's Avatar
Licensed to Spell
You need to ground your starter properly. The starter grounds through the transmission and as our cars age, the connection at the bell housing at the two halves of the transmission degrades. Run some wire from one of the starter bolts to a bolt on the other side of the trans and/or straight to the negative battery terminal.
Old Oct 26, 2006 | 04:08 AM
asperos28's Avatar
i had to put some wires on it already from when i did the 5 speed swap, i got one from the starter to the neg terminal and one from the front of the tranny to the neg terminal, so i dont think thats the problemm
Old Oct 26, 2006 | 05:47 PM
kbz504's Avatar
Sounds like a ground to me.
Old Oct 26, 2006 | 09:36 PM
Digitized's Avatar
what do you mean by:"my car and it cranked but wont turnover"? are you saying the starter just keeps "turning"and no spark ? or are you saying you hear the "Click" when you turn the key and that's it?
Old Oct 27, 2006 | 08:09 AM
asperos28's Avatar
the starter just cranks and cranks, but the wierd thing is if i reset the ecu it starts fine, and then wen the check engine light turns back on it gets all gay again
Old Oct 27, 2006 | 08:16 AM
willard00's Avatar
if starter wasnt working it wouldnt crank at all.
and why dont you check the codes?!?! maybe that will give you the answer....
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
