Clutch replacement time...
Old Oct 26, 2006 | 06:31 AM
djmaverick's Avatar
Runs with scissors
A little background first...
I currently have an ACT 6 puck (stage2) clutch and it needs to be replaced. I also have an Unorthodox Flywheel. I want to replace it with the same thing and I really don't feel like attempting to do this job myself. I am mechanically inclined, but when it comes to dropping a trans, I am not too confident (nor do I have the time or place to do it). I realize I am going to pay about $500-600 to get this done. My question is does anyone else have this setup (or something similar)? I've looked at the ACT setup I have online and it seems that I just need to buy the single 6 puck clutch disc (or am I wrong?). Also, one of the shops I asked about doing this said something about re-surfacing the flywheel. I've looked at the Unorthodox web site and it states that they have replaceable "Heat shields" and that you cannot re-surface these. Does anyone know if this is the case? Any help would be greatly appreciated.
Old Oct 26, 2006 | 08:59 AM
dgeesaman's Avatar
Maintenance Monster
You haven't mentioned what torque you're putting down, which is possibly the most important parameter.
Clutches should only be as heavy as necessary - you will get rougher engagement, faster wear, and more driveline shock (aka broken trannys and axles) using more clutch than you need.
Dave
Old Oct 26, 2006 | 09:27 AM
djmaverick's Avatar
Runs with scissors
Right now I think I'm a little over stock. I have intake, full exhaust (except headers), flywheel (obviously), computer, and some other minor things. I am planning on boosting hopefully soon. I am also going to be getting a LSD soon too as well. I bought the car with the clutch and flywheel already installed and I liked the response (even though it took a little getting used to at first).
Old Oct 26, 2006 | 01:35 PM
djmaverick's Avatar
Runs with scissors
Anyone...?
Old Oct 26, 2006 | 05:29 PM
skweaky's Avatar
i hear that u should stick with the stock clutch untill you pass 300whp. so with just boost and no internals even then i would stick with a stock or stage one setup. stock for now untill you boost if you think it will be a long time befor you make that jump.
Old Oct 26, 2006 | 05:41 PM
DuMKuH's Avatar
Just get a 5th gen setup until you boost and get LSD.
CorollaULEV
30
Aug 9, 2021 08:11 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
vanebecker
Aug 17, 2015 08:24 PM
