Is 100 bucks fair?
Old Oct 27, 2006 | 07:04 AM
babymac's Avatar
BOOST 4 LIFE!
Is 100 bucks fair?
Is 100 bucks shipped for a used 2000 maxima fuel rail with injectors a good deal?
Old Oct 27, 2006 | 07:22 AM
densetsu's Avatar
hell yeah! the fuel rail itself is easily $50-100... with injectors that is a done deal as far as im concerned.
Old Oct 27, 2006 | 08:59 AM
moogotzskillz2's Avatar
^^^^^yaaaa
Old Oct 27, 2006 | 10:23 AM
matts95max's Avatar
like the others said..YES. a fuel injector, 1, from nissan is more than that!
Old Oct 27, 2006 | 10:32 AM
RichMax's Avatar
Boosted like Snipes tax refund
+1 agreed... I paid a bit more for some 300zx injectors, but you get the point. price a single new injector Nissan injector for a DE-K... after you get over your sticker shock, buy this guy's fuel rail... if it's still around and he's a good seller...
Old Oct 27, 2006 | 02:11 PM
babymac's Avatar
BOOST 4 LIFE!
I know this isn't a must when doing a 00vi swap. So whats the advantage of a having it?
thanks
Old Oct 27, 2006 | 03:18 PM
RichMax's Avatar
thanks
imho there is no benefit unless the increase in fuel delivery capacity that results from putting in a fuel rail with larger injectors is accompanied by an increase in the amount of air delivered to the engine. There IS an increase in the amount of air delivered by the improved de-k intake manifold....
Old Oct 27, 2006 | 04:27 PM
babymac's Avatar
BOOST 4 LIFE!
Yeah I'm thinking I am not going to use the dek injectors. I'll just use the 4th gen.'s
Old Oct 27, 2006 | 04:43 PM
RichMax's Avatar
Brief corollary to what I said earlier.. that increase in air delivery isn't a huge one (like the one you'd get if your car was forced induction).
Old Oct 27, 2006 | 04:50 PM
babymac's Avatar
BOOST 4 LIFE!
so there is no need for the injectors?
Old Oct 27, 2006 | 05:21 PM
Cdg2125's Avatar
It's a fair deal but you're paying extra money for that stuff. It's cheaper to use the 4th gen stuff. No benefits from using all the 5th gen stuff really unless you're using V-AFC II or JWT or something to manipulate all that stuff.
Old Oct 27, 2006 | 05:26 PM
babymac's Avatar
BOOST 4 LIFE!
Thats why i decided not to. I also scrapped the bipipe and just want this 00vi done. I don't think there is enough hp(maybe 3) in a b-pipe to justify 200+ when for about 400-500 give or take I can have a 00vi which with my ecu could give me 15 or more hp especially if ts tells me they can re flash my ecu, which they tell me they might because i don't have the higher rev-limiter YET!
Old Oct 27, 2006 | 05:28 PM
t6378tp's Avatar
Turbo 3.5
Hey are you doing the install yourself or will you have some-1 else do it.
If you are doing the install can I watch or help, I want to see how it's done and maybe pickup some tips.
I am kicking around the idea of doing this mod in the future myself
Cdg2125's Avatar
I'm not sure about the TS ecu. I havnt heard too much about it. I dont know if it will give much extra gain to the 00vi. B pipe is worth it since the extra air from the 00vi will need to go out....but yeah I think using the 5th rails and all is too much extra work.
Old Oct 27, 2006 | 06:03 PM
babymac's Avatar
BOOST 4 LIFE!
The ecu is a BIG improvment over the stock one i had. Bigger then the y-pipe.
Old Oct 27, 2006 | 06:16 PM
Cdg2125's Avatar
Yeah but I'm not sure how it works with the 00vi. I've never heard anyone using that kind with the 00vi swap.
Old Oct 27, 2006 | 06:47 PM
babymac's Avatar
BOOST 4 LIFE!
It does the same thing as the jwt. Advanced fuel curves, advance timing for 91 octane, etc.... It will definitely help ALOT with the 00vi. I just hope they can reprogram it for the higher rev limit.
Old Oct 27, 2006 | 06:49 PM
Cdg2125's Avatar
Still havnt heard anything about anyone using that kind of ECU. I'm just telling you. I've read a lot about them, and V-AFC II or JWT are the recomended. I'm sure it will work fine tho.
Old Oct 27, 2006 | 06:56 PM
babymac's Avatar
BOOST 4 LIFE!
I was also thinking about using the vafcII along with the ecu. This way i won't have to use a rpm switch right?
Old Oct 27, 2006 | 06:57 PM
Cdg2125's Avatar
No the V-AFC II will take care of the rpm switch plus reulating things. It's a waste of your money really. If you have an upgraded ECU you wont need the V-AFC II as well.
I'm just using the MSD then buying the V-AFC II later when I find a good price.
Old Oct 27, 2006 | 07:15 PM
babymac's Avatar
BOOST 4 LIFE!
Well right now I've come to this conclusion: 00uim,4th gen lim,4th gen fuel rail and injectors, 4th gen throttlebody, msd switch, 00egr guide tube,4th gen rear valve cover, and some 00 rear bank ignition coils. What did I forget???
oh and adapter plates for the iacv and throttle body.
Old Oct 27, 2006 | 07:24 PM
Cdg2125's Avatar
Thats the basic setup. You'll just need a lot of little stuff.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
msellas
Sep 23, 2015 09:16 PM
