MAP sensor. where? how? why?
Old Oct 27, 2006 | 07:05 PM
hitman4's Avatar
MAP sensor is out! anyone got any experience in getting or changing one? Or if you know anything about it, any info would be much appreciated
Definition: Refers to a manifold absolute pressure sensor, a variable resistor used to monitor the difference in pressure between the intake manifold at outside atmosphere.
-This information is used by the engine computer to monitor engine load (vacuum drops when the engine is under load or at wide open throttle). When the engine is under load, the computer may alter spark timing and the fuel mixture to improve performance and emissions.
Old Oct 27, 2006 | 07:09 PM
Nealoc187's Avatar
SLOW
I have 2 of them for sale if you decide you need to replace it. They are easy to replace, though our motor has like 3 of them so you need to determine which one is bad.
http://forums.maxima.org/showthread.php?t=493785
Old Oct 27, 2006 | 07:24 PM
hitman4's Avatar
looks to me like all three of those sensors are identical. are you sure i need to find out which one i realy need?
Old Oct 27, 2006 | 07:31 PM
Nealoc187's Avatar
SLOW
they are identical. what i meant was you need to find out which one on your car is bad so you can replace it. you have 3 of them, but only one is bad most likely, thus you only need to replace one, but you have to find out WHICH one you need to replace...
Old Oct 28, 2006 | 06:07 AM
crazy97's Avatar
What are symtoms of a bad MAP sensor? Just curious.
Old Oct 29, 2006 | 02:10 AM
crazy97's Avatar
Anyone know?
Old Nov 4, 2006 | 03:10 PM
hitman4's Avatar
Your car starts sounding like a tractor. LITERALLY. Very very bad vibration from the motor. Slows down ur car realy realy bad and eats gas like a maniak. thats what i am going through right now. freekin SUCKS. cant wait to get that shlT fixed. oh...and another thing. Ur "check engine light" starts blinking whenever you accelerate, because there is no pressure.
Old Nov 4, 2006 | 03:18 PM
nismology's Avatar
1. The absolute pressure sensor is not used directly for engine control. Diagnostics only.
2. A blinking CEL indicates a multiple cylinder misfire. Either partially clogged injector or faulty ignition coil.
3. Our cars utilize a Mass air flow sensor to determine how much air is entering the intake manifold.
Old Nov 4, 2006 | 05:05 PM
pmohr's Avatar
No more Maximas...
Or a bad plug, intermittent short in coil or injector harness.
Old Nov 4, 2006 | 06:46 PM
RA030726's Avatar
I'm nutty for Nissans
The MAP sensor is not what Neal has listed. Those are solenoid vavles for the emmissions. The MAP sensors is on the intake snorkle and says "boost sensor" on it.
Old Nov 4, 2006 | 07:29 PM
nismology's Avatar
Old Nov 4, 2006 | 07:32 PM
RA030726's Avatar
are you serious?
Old Nov 4, 2006 | 07:55 PM
nismology's Avatar
Yea cus i wasn't too sure who or what you were responding to.
Old Nov 5, 2006 | 10:19 AM
RA030726's Avatar
i was informing the original poster of where the MAP sensor is, and to clarify what neal has are not sensors.
Old Nov 5, 2006 | 11:03 AM
Apparition's Avatar
Ichiban King
haha I wired that damn thing outta the way when I first got the car, I was like WTF is that crap..
Old Nov 6, 2006 | 06:22 PM
hitman4's Avatar
WHAT?! sh't no nono.....fak. i just sent him the money. probly should have read this thread first. Thanks guys. it makes sence. there is only 1 map sensor in the car not 3. and the guy in the shop told me that there is only 2 problem codes: MAP sensor and Knock sensor. i have been driving with a bad knock sensor for 2 years now, so i didnt think that it was THE problem. but now i think that it IS the problem
Old Nov 6, 2006 | 06:30 PM
hitman4's Avatar
It happened when i drove the car uphill and as the car could not pull anymore without pressing the gas i parked it without turning off the car but basicly letting it run untill it stopped on its own and shut off. Didnt press out the clutch by accident. and when i started it: this happened.
Old Nov 14, 2006 | 05:59 PM
hitman4's Avatar
I dont have much money to play around with so i dunno if i should just risk it and change my injectors. Any1 suggest a good way to fix the problem with little guess work?
viperboy
Sep 27, 2015 07:05 PM
zmcneely13
Sep 26, 2015 02:26 PM
RWCreative
Sep 21, 2015 11:01 AM
